Features include:
- Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
- Unlimited 3D GPS waypoints
- Built-in camera control
- Fully-scriptable missions
- One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
- Replay recorded missions and analyze all the data with a graphing interface
- Supports two-way telemetry with Xbee wireless modules.
- Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
- Fly with a joystick or gamepad via your PC--no need for RC control!
- Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
* APM 2.5 autopilot with GPS ($179)
* [Optional] Telemetry kit ($75).
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies! (We're partial to the SkyFun delta wing (right) and
Bixlee 2 powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
Earl
The name have "Shield/OilPan" because it's possible to attach it by the two ways. One of the main advantages of use it as shield is the existence of mounting holes on APM. So with APM at the base, you can use those holes. When you mount APM with bolts on the ArduCopter's plates, for example, you have a more secure and affordable way to manipulate all the connectors (PWM/RX, GPS or the Compass module on the IMU shield as well ).
Regards.
I have a question:
Can someone tell me where the advantage is building the IMU on top of the Mega vs. Underneath the Mega in oilpan configuration.
I was guessing because it was named oilpan it would be better to add it to the bottom, but now all the graphics are showing IMU on top.
Which one is better?
Out of curiosity, has anyone got this running on a BETA main board yet? We've figured out the HW MUX is on a different channel, and I can switch modes and have full Tx control now, but I'm getting no response to the servos from IMU movement.
Just wondering if we have "known" config changes necessary from beta to production firmware.
JC
