Features include:
- Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
- Unlimited 3D GPS waypoints
- Built-in camera control
- Fully-scriptable missions
- One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
- Replay recorded missions and analyze all the data with a graphing interface
- Supports two-way telemetry with Xbee wireless modules.
- Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
- Fly with a joystick or gamepad via your PC--no need for RC control!
- Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
* APM 2.5 autopilot with GPS ($179)
* [Optional] Telemetry kit ($75).
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies! (We're partial to the SkyFun delta wing (right) and
Bixlee 2 powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
Thanks . Hats Off to You All !!!
Joe
As written ArduPilotMega will not compile if the "libraries" are not in the arduino-0019 's "libraries" file folder that is created when one extracts the "arduino-0019.zip" file.
my question to you is this; Could you possibly while developing/codding/debugging/etc. have these library files in the arduino's "libraries" folder? If you do that is the problem! If on the other hand you only have the standard "arduino packaged libraries" eleven in all in arduino's "libraries" folder , then you are wrong!
Check that folder and delet all but the eleven libraries you will see what we are seelig. It does not matter what preferences :
looks like.
I have been around this tree a thousand times in the last three weeks.
Joe
By the way, my PC still thinks all my old ArduPilotMega alpha files are in use, and won't let me delete them (even if I try to delete them right when my PC finishes booting up). I'm guessing that SVN somehow marked them as in use. If anyone can think of a fix to that problem, please let me know.
