ArduPlane home page
3689354430?profile=original
3689312509?profile=original
Convert any RC airplane into a fully-autonomous UAV!
Just add the APM 2 autopilot to any RC aircraft and it becomes a fully-programmable flying robot with a powerful ground station and Mission Planner.
Features include:
  • Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
  • Unlimited 3D GPS waypoints
  • Built-in camera control
  • Fully-scriptable missions
  • One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
  • Replay recorded missions and analyze all the data with a graphing interface
  • Supports two-way telemetry with Xbee wireless modules.
  • Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
  • Fly with a joystick or gamepad via your PC--no need for RC control!
  • Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
3689354391?profile=original
3689354242?profile=original
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
APM 2.5 autopilot with GPS ($179)
[Optional] Telemetry kit ($75).
3689354459?profile=original
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies!3689354440?profile=original (We're partial to the SkyFun delta wing (right) and
Bixlee 2   powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
  • @Chris, Thanks for the update, but the problem, unfortunately, remains. I'll do some more poking around to make sure it isn't something on my end, but I did try loading the code with no changes except to uncomment the proper GPS option in APM_Config.h without success, and reverting to an older version (not sure which, filenames are identical) of the beta .zip works fine.
    @Brett, @Michael: I've uploaded a new zip file with the fixed library. That should do it, but let me know if there are still any issues.
  • @Michael: Great, thanks!
    @Uwe - I think timer 2 is currently unused.
    @Brett - This was a bug in the library code introduced in r760 and fixed in r809 yesterday. If you are working from the 1.0-Beta Sketchbook in svn, update and you should be good to go. Otherwise, the next zipfile should address the issue.
    Brett: Thanks for the heads up...we'll check that out.
  • It looks like something in the newest Beta broke the CLI. The CLI loads fine, but produces no output when a command is issued to it. Reverting to the previous version fixes the problem. I also noticed some extra output in the new version when using the serial monitor with the switch set to flight mode (switch flipped toward the board).
  • For some reason I just don't have GPS data. The logged GPS data shows all zeros. The TM data stream does not include the location message. However, the CLI GPS test displays the GPS data correctly (with the exception that the number of satellites is always reported as 0). I updated my MediaTek software last week, and it fixed the problem that I was having with incorrect lattitude. Any thoughts? Thanks!
  • I have had great success with the Stabilize and Fly By Wire modes. In an effort to move forward, I tried RTL mode today. Every time I switched into RTL mode the plane simply banked into a left hand descending spiral, regardless of where it was located relative to the launch position. I examined my logged flight data, and the GPS data is all zeros. This is odd, because I used the CLI to run a GPS test immediately before the flight and it was reporting my position just fine (with the exception that the number of satellites is always reported as 0). Per Chris' instructions I updated my Mediatek software last weekend (before the update, I did not obtain valid position fixes when running the CLI test). Any thoughts? Thanks!
  • thx, man. I'll read through the thread.
