Features include:
- Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
- Unlimited 3D GPS waypoints
- Built-in camera control
- Fully-scriptable missions
- One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
- Replay recorded missions and analyze all the data with a graphing interface
- Supports two-way telemetry with Xbee wireless modules.
- Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
- Fly with a joystick or gamepad via your PC--no need for RC control!
- Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
* APM 2.5 autopilot with GPS ($179)
* [Optional] Telemetry kit ($75).
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies! (We're partial to the SkyFun delta wing (right) and
Bixlee 2 powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
you can use the 4 pin header next to that port for your gps. the 4 pins are marked next to the gps connector. see pic,
http://ardupilot-mega.googlecode.com/svn/ArduPilotMegaImages/IMG_47...
you can make a cable out of your old gps cable.
@eng.a.ramdan: currently, we can command up to eight motors through APM outputs. You can take a look at this ArduPirates page, they have Hexa and Octo ones there:
http://www.rcgroups.com/forums/showthread.php?t=1286011
@eng.a.ramdan, actually you don't need necessarily to increase the size of frame, motors and propellers. However, you would to add motors.
Hexa and OctoCopters are more strong and more efficient than Quads. The "efficiency" part sounds weird, I know that... but is a fact. When the copter have more than 4 motors they all will work at less RPM, so you will deal with the best part of the motor's drag curve (power vs efficiency). So when dragging that payload, your hexa/octocopter will for sure drain less battery than a super-big quad. ;)
@end.a.ramdan, if your frame is too bigger than normally is... you will probably need to change the PID values.
The more it is bigger, the more it will delay to tilt. It could be good in terms of stabilization by the same way it could be very bad, when you need to correct the angle quickly. So, think about adopt one of the standard ArduCopter sizes, and you'll be fine.Larry,
That's old language from the original ArduPilot manual--I've removed it. Sparkfun has recently screwed up their Xbees by ordering them with mesh networking firmware, which needs to be overwritten for our purposes. The manual explains how:
Because of this, we're going to start offering Xbees and other wireless modules that are set up right, straight from the factory. People shouldn't have to deal with that nonsense. But if you follow the above instructions, it should be fine.
7
8
9
10
11
of 59 Next
