3689393964?profile=originalBy popular demand, ArduPilot Mega is now available as an all-in-one kit for $250. It includes everything you need for a functioning autopilot with GPS, even including RC cables.
We'll soon be offering wireless telemetry options for this, too, along with a ArduCopter version that comes with a magnetometer. A pre-soldered version of APM will also be available in a month or so, once we put in place a rock-solid testing process.
In the meantime, you can buy APM pre-soldered with code loaded and tested from uDrones for $349.
  • Here is the main use for my ftdi cable though...
    3692183626?profile=original
  • I haev loads of reasons for owning a ftdi cable, upgrading firmware on ublox, and xbee, configuration changes on xbee and ublox, direct connect to telemetry port for hil on usb and gcs on ftdi to the groundstation with no need of running xbee's, um... plus more but you get my drift. But to include? I dunno, but I bought mine with the APM board before the IMU had came out. so it was required :)
    dydx:
    1) Why would anyone need an FTDI cable? APM is USB native.
    2) The DIY Drones factory makes its own APM boards now.
    dydx, it does not need any FTDI cable just normal USB cable is enough. IMU board has FTDI adapter onboard.
    Dave, it's no harder than an Arduino shield. APM has a whole suite of tests to check every part of your hardware. It's all interactive and pretty easy to use.
  • I knew there was a reason I was holding off buying my APM!  This will make life much easier.  Thanks.
    dydx: we're just selling the electronics, which are not export controlled by themselves. It's not an autopilot without code. If you want to buy it with code loaded, you need to buy outside the US at udrones.com
    http://udrones.com/
    Michelle: it's $12 (5%) less than the parts sold separately.
  • Is there a price break on the kit vs. individually? I know I could add it all up, but if some one knows the answer, that would be great.  Thanks!
  • Hmmmm I have a birthday coming up. Nice job guys!
