ArduPilot Mega v1.0.3 alpha ready for public release
OK - After working with a small group of Alpha testers, I guess we are ready to open the flood gates and make a public release of ArduPilotMega!
Here is what you need to know:
  • This is an Alpha release - expect there to be bugs. If you don't want to deal with bugs, wait for the Beta. There will still be bugs in the Beta (probably), but a lot less.
  • For the Alpha release we will NOT be providing a .zip download. The code will be changing frequently as we find and fix bugs. You should use a SVN client to get the most recent revision to the code. Look below for a mini tutorial. If you don't want to mess with SVN, please wait for the Beta release.
  • Read the ArduPilot Mega manual. It is located here. Expect the manual to change on a daily basis. Recheck it frequently.
  • Please understand that there is a HUGE amount of functionality in ArduPilotMega. Most of it is still untested in actual flight, and some specific commands are not fully implemented.
  • We have made extensive use of libraries. You must either add these to your Arduino install or we would recommend using the great new "Sketchbook checkout" put together by Michael Smith which will handle getting the libraries for you and keeping them current. See the SVN mini tutorial below.
  • There is some functionality in place for the Legacy ground station. There is also functionality in place for the new ground station, however the new ground station is not ready yet.
What has been tested successfully? We have tested the basic flight modes (Manual, Stabilize, Fly By Wire, Auto) and the basic commands (Navigate to Waypoint, Loiter commands, and RTL)
What has not been tested:
  • Airspeed Sensor and associated control laws
  • Magnetometer
  • NMEA
  • Most of the commands
  • Use of many of the options in the config file
How can you help? If you feel you are up to Alpha testing, then join in. We are taking bug reports through the Google code repository "Issues" feature. You can find that here.
Good luck and happy autonomous flying!
Mini SVN Tutorial
This is a quick tutorial on how to use Tortise SVN to download the ArduPilotMega code using the "Sketchbook checkout" and how to keep your copy up to date.
  • Install the TortiseSVN client on your PC. Get it here.
  • On your PC open a window for the directory into which you would like to store your local copy of the code. Right click in the window and choose SVN Checkout.
  • Fill in the URL of repository with: http://ardupilot-mega.googlecode.com/svn/Sketchbook/trunk/
  • The checkout directory field should contain a folder name of the folder you are in appended with \Sketchbook
  • Click OK. This step downloads all the firmware and library files you will need. If you have a slow connection this step can be glitchy. If you get an error that one or more libraries you can use the SVN update feature to correct this after the checkout completes.
  • You should now have a Sketchbook folder which contains folders for ArduPilotMega, libraries, and Tests.
  • Open the Arduino IDE. Go to Preferences in the File menu. Change the Sketchbook location to this new Sketchbook folder. Now choose Sketchbook from the File menu and choose ArduPilotMega.
  • You are now ready to compile the latest code.
  • To update your local working copy to the latest revision, go to the directory containing your Sketchbook folder, right click on the Sketchbook folder, and choose SVN Update. With this one step you will get the latest code for ArduPilotMega and all the libraries downloaded to your PC.
    There's nothing wrong with tinkering.
    But saying "I tried X and it didn't work like and I didn't look at the code or attempt to debug anything" isn't consistent with 'alpha release'.
    Unless you have a GPS attached and have completed the ground start (solid red and green LEDs, no blinking) then this is expected.
    Please folks, this is an alpha release. If you can't read the code and the schematic this is *not for you*.
    If you don't have valid ground start data in EEPROM yet then I wouldn't pay much attention to the altitude value. If the pressure value is showing up and changing, that is what you are looking for.
    Have you set the 4 serial baud rates in the config file like toh's post above? When you get the starting message then do you get a bunch of LED flashing on the oilpan? There will be no additional text output till the calibration is done which will be after a couple sets of flashing LEDs.
  • ok i have solve mine.
    Go to APM_Config.h change all to
    #define SERIAL0_BAUD 38400
    #define SERIAL1_BAUD 38400
    #define SERIAL2_BAUD 38400
    #define SERIAL3_BAUD 38400
    next
    GPS configuration
    #define GPS_PROTOCOL GPS_PROTOCOL_IMU
    Telemetry
    #define GCS_PROTOCOL GCS_PROTOCOL_IMU
    Finally go to GCS_IMU_output and change all Serial to Serial3 example:
    Serial3.print("AN0:");
    Serial3.print(read_adc(0)); //Reversing the sign.
    Serial3.print(",AN1:");
    Hope this can help you to solve the problem.
    Please follow the instructions on the wiki here: http://code.google.com/p/ardupilot-mega/wiki/Wireless
  • Thanks Michael. but the problem still not solve yet.
    So i have change my ground xbee to 38400 and the APM_config.h Serial3 to 38400. No reading on the ground xbee.
    And is my connection correct?
    cheers
    Check your APM_Config.h; I believe the current setting for Serial3 is 115200.
  • Hi all i have some questions to ask.
    First i have compile and load in the ArduPilot Mega v1.0.3 alpha code. No error was found.
    But the problem is my ground station xbee is not receiving. But my APM i sending this
    baud rate is set as 38400. Is it right?
    All this is in the manual, BTW.
