So I have some vacations coming up and already have some quads and a hex I figured I needed a fixed wing to round out my aerial camera fleet. (for now) heh. So I took the plunge and picked myself up an X8 to fill up with electronics.
I'm running an ArduPilot Purple, with a Castle 75 esc waiting for Hobbyking to drop of my new Scorpion motor until then I have a 700W max 50Amp local hobby store motor to power the bird. I'm running 1.2 video feeding through MinimOSD with a Sony 720 line mini cam. I have a roll and tilt GoPro mount in the works that I'll post up some pics when I can get some play time on the router this weekend. Communication is done through a Futaba 10C 72Mhz and some 900Mhz XBees.
I've only made a few mods for now like adding a second motor mount plate that bolt through the foam to the outer plate.
I made some electronics trays and filled in the lower camera cut out with some foam and Gorilla glue.
I ended up bringing the control linkage up through the wing, leaving it on the bottom seemed like a bad idea for a belly lander. I have never flown a or built a fixed wing, but I said the same about the multirotors and DIYDrone's gear and community made it simple, awesome and enjoyable. Only crashes were ah-hem user error. So I'm hoping for the same luck with this bird. I do have tons of hours now on RealFlight sim just to make sure I feel comfortable with the controls. That being said any input from from you guys will be greatly appreciated. I'll update this blog as things progress and as I get the camera mount going. But for now heres some more eye candy. Be happy and safe all!
Wow, that's a really nice setup you're doing there, and some top notch equipment. Nice radio. The 10C is a great choice because it is a nice Futaba transmitter, good feel and great quality, but it still uses "modules" so you can switch between 72MHz and 2.4GHz as required.
Does the 10C 72MHz have any failsafe function though? You might want to look into the FrSky 2.4GHz modules.
Also, the Turnigy Nanotech battery packs are probably overkill. I'd have just used some cheap 20C packs, it's more than enough. I have a bunch of them and they are possibly more durable (long term performance) than the Nanotechs. It's just sort of hearsay at the moment, but it might be true.
Lastly, you should replace the screws you have holding down the APM2 with nylon ones, just to eliminate the possibility of mag interference.
I just read that the X8 has a valid payload between 1000-2000 g. Whow!
What's the flight time of such a big bird ?
10
11
12
13
14
of 14 Next
