Hello ArduPilots,
Here you will find my latest updated version of the ArduPilot (v2.7.4a JLN) successfully tested in autonomous flights with a Multiplex Cularis (GPS Ublox and ArduIMU v1.6). This version runs very well with the GPS Emulator v1.1.45 and you may test it yourself at home.
More photos at : http://diydrones.com/photo/albums/ardupilot-and-arduimu-on-a
The full software can be downloaded at: http://code.google.com/p/ardupilotdev/downloads/list
Here the test procedure with the GPS Emulator:Required material: Ardupilot with or without shield, it works also with Arduino board "Duemilanove"
1) Compile and upload the ArduPilot_2_7_4_JLN software to your ardupilot board
2) Download a flight plan with PlanifMission.exe (v 1.4.14), i.e. upload the flight plan "fieldtest4"
3) Run the GPSEmulator.exe (v 1.1.45):
a) choose the ardupilot comm port: i.e. COM10 then click 'Connect'
b) Select File/Run ArduPilot Mission
c) Selected Mission 'fieldtest4'
d) GPS Data Source 'GPS Emulator w/ArduPilot'
e) check 'Listen to Throttle'
f) Click on the 'Start' button on the main window
Enjoy,
Jean-Louis Naudin
Main JLN DIY Drones page: http://diydrones.com/profile/JeanLouisNaudin
Google code: http://code.google.com/p/ardupilotdev/
(in french) Oui, bien sur, l'ardupilot fonctionnera sans pb sur ton Easystar. Tu auras simplement besoin de refaire un réglage fin du gain des PID dans AP_PID_set_xxx.h
Jean-Louis
cordialement
DODY.
Yes you may use this with the Easyglider, the code for GPS EM406 is now working well, in the original code there was a bug which unlock the GPS each 3 seconds. This is now working. I have tested this version with my Easyglider with ArduPilot, shield v2, Thermopiles sensors and GPS EM406.
The best is to use the ArduIMU, the flight is very stable in windy and gusty conditions and of course in foggy conditions...
Jean-Louis
