AUAV-X1 , a new vision of the PX4 autopilot
3689573411?profile=original3689573537?profile=original
Arsov RC Technology is proud to introduce a new vision of the PX4 v2 Autopilot board. The Arsov AUAV X1 is another elegant design from Phillip Kocmoud and Nick Arsov. Our goal was to product a high quality, compact, lightweight and cost effective alternative to the PX4 V2 or PixHawk autopilots. This is our first attempt to join the PX4 community after developing several successful designs for the MatrixPilot community. After we have finalized the design we will release the design files and schematics. The schematics will be released immediately to new owners. Initial supplies are limited and a deposit insures a boards in the first production run.
Availability:
Early March , 2014
Features:
STM32F427VI ARM MCU
STM32F100C8T6 ARM MCU
MEAS MS5611-01BA03 barometer
Memory - 8Mb SPI Flash. Could be expanded on demand up to 1Gb.
microIMU – choose one of the following 5 IMU offerings:
-ST Micro L3GD20H + LSM303D
-ST Micro L3GD20H + LSM303D + MPU6500
-Invensense MPU 6500
-Invensense MPU9250
-Maxim MAX21100
-Connector only for remotely mounted IMU
New power supply based on TPS63061 DC-DC Buck-Boost
The TPS63061 device provides a power supply solution for products powered by either three-cell up to six-cell alkaline, NiCd or NiMH battery, or a one-cell or dual-cell Li-Ion or Li-polymer battery. Output currents can go as high as 2A while using a dual-cell Li-Ion or Li-Polymer Battery, and discharge it down to 5V or lower. So you can connect a 2 cell Li-Po directly to the AUAV X1, and run it completely flat before brownout. Since it's a buck-boost converter, you can also power from a 5V BEC while still in regulation. Additional info about this Buck-Boost regulator could be found here - http://www.ti.com/product/tps63061
Connections:
4 x UARTs - 3 of them have Vcc, Tx, Rx, GND and one has a full set - Vcc, Tx, Rx, RTS, CTS, GND
1 x CAN with MAX3051
1 x I2C
1 x SPI
2 x ADC + 2 x ADC for current and voltage sensing
8 x PWM Receiver Inputs
8 x PWM Servo Outputs
2 x JTAG connection specifically for the TC2030-CTX-NL 6-Pin cable
micro SD card holder
micro USB connector
All inputs and outputs are ESD and EMI protected
Dimensions:
30mm x 43mm
For additional information and availability, please visit our websites https://store.auav.co/ for US or http://arsovtech.com for EU.
  • Hi Doug,
    Yes, I know the PDFs and the application files are for MAX21000, but 21100 register info is still not available at Maxim.....very frustrating.....
    I have configured the SP0 pin per the data sheet for the next-to-LSb to be zero and have tried 0xB0 and 0xB1 in accordance with the data sheet which may of course be wrong.  I can set up to just bang all the addresses and look for a response though…  I'll carry on with all the typical debugging stuff - was just hoping it may be a problem someone else has already solved :)
  • Doug, have you tried ALL I2C addresses looking for ACK?
    Data sheet listed  address 101100X  where x might be a config pin.
    So if your I2C library takes a different address for TX and RX then I'd try
    Read 0xB1 or 0xB3
    Write 0xB0 or 0xB2
    If it takes a single address for TX and RX then I'd try
    0x58 and 0x59
    Hi Nick,
    The files you uploaded are for the 21000 series devices, which are 2 axis devices, versus the 21100 series devices which are 6+3 axis devices.  Although there are some similarities there are very significant differences.  Is there some portions of the library code you have found useful?  I could see that perhaps the bitfield for the Scale Factor, for example, could be the same, although there certainly is no guarantee.  The bitfield for the Power Mode would most likely be incorrect as there are more power modes for the 21100, etc...
    My problem has been even more basic.  When trying to talk to it by I2C I always get a nack and never an ack….
  • Hi Doug,
    Unfortunately I'm still waiting the register map too, but I could give you some useful info about MAX21000.
    Just call me at my DIYdrones Inbox to send you the files. I'm not familiar how to apply pdf and zip files here.
    Nick
    Does anybody have any actual experience with the Maxim21100?  I have a couple sample parts but thus far have not been able to get anything out of them.  Of course the data sheet doesn't help - it is missing all the register bitfield info, etc. etc.
  • Hi Toby,
    You have many options for powering the AUAV-X1:
    1. Any ESC with 5V, 6V or even higher...say 8VDC;
    2. A DC-DC Brick - like the one for powering the PX4 or PIXHAWK;
    3. A 2S Li-Po;
    4. Any other source or DC-DC module with output voltage between 4VDC and 12VDC.
    I personally recommend any source within 4VDC and 8VDC.
    About the GPS - you may get any you would use with PX4 or PIXHAWK. The AUAV-X1 when using a ST gyro/accelero/mag set ( L3GD20H+LSM303D ) offers a compass on board, no external needed.
    Nick
  • Thanks for the clarification. I was surprised when you said that, MPU6.5K is on the brim of technology standards.
    And hope to see MPU8K some day soon :)
  • Shyam, I am sorry, I should have said its future on the PixHawk board is questionable per this message thread in the PX4users group: https://groups.google.com/d/msg/px4users/62GpxjmQBvs/GoQhsxe_ldMJ
    We do know Invensense suggests the similar but smaller MPU6500 for new designs, so the MPU6000 will be sunset at some point.
