Baro for $5
New Product on MouserLast time I looked barometers were fairly pricey. Add this to a $2 relative pressure sensor and you've got both atmospheric sensors in the single digits.
  • Interesting to see a small analog sensor like this. Not really $5 though, only if you plan on buying 500 (still $5.81)
    The Bosch BMP085 would probably be a better choice if you can afford to use an I2C interface.
    From the datasheet, internally it seems to be only 10bit which is disappointing.
