Last Wednesday I went out to the field for some flight tests and gains trimming. Other people where flying their model planes there too. We usually follow a counter-clockwise pattern while flying to avoid collisions. That day I was flying especially slow, so when I took the turn, I did so on the spot and ended on the wrong lane. By the time I realized that, someone rammed me out of the air.
If I remember the even correctly, and the flight replay (LOG00212.kmz), the collision should be head-on. However, the reason I fell, was because the other plane's propeller clipped my left aileron. I managed to crash-land while doing semi-controlled spirals, losing a wing, the propeller and a wheel.
Afterwards, I tried to do some black-box analysis, with interesting results:
Firstly, here is a graph of the altitude, and the magnitude of the acceleration vector and angular speed vector:
The collision occurs at about the 120th second. I estimate the moment at 120.5s. Strangely, no acceleration or angular motion peak is noticed at that moment. Only after I try to pull up at 124s is acceleration recorded, and, of course, at the crash. The IMU is supposed to be set at +-8g limit.
The roll, pitch and yaw plots are a bit more indicative of the situation:
Roll goes crazy after I pick the plane up from the tail and carry it back to the car. It's expected.
In the last two graphs, a violent change in direction is noticed, in contrast with the first plot.
To sum up, I didn't find the accelerometers a good source of information, in order to detect a mid-air collision. Instead, angular velocities are more reliable, with proper thresholding.
In retrospect, airspeed data would be nice to compare as well, but for some reason, the airspeed kit doesn't return correct values. I 'll have to look more into it.
Mine was not a mid-air, but a wing failure mid-flight. (long-o tell-o so will end there.)
But way to go on your patience to collect post-crash investigation data. I know how it can feel to recover a downed plane.
I love the title of this blog post!
