After getting the board from 3D Robotics, motor from RCtigermotor, ESCs from HK... some stuff from Flytron as well.. I started to build:
1. Materials
Frames: DIY CNC Fiber Carbon + Alu 10x15mm x 340mm long
assembled motor to the arms:
with ESCs:
with landing, the FC one is too weak and I could not use it. I used landing of Heli500
with ArduCopter control
The other view:
foldable:
This has been tested out in Loiter mode and it worked very well. Will check more with Circle and Auto mode.
Hope I can have video clip soon
cool stuff
I disconnected red wire from all ESCs, I did not use BEC from ESCs, I used seperate Ubec. :). The last pic is the final, so some confused :)
If you plug all the ESCs into the board depending on how the ESCs regulate voltage they might fight with each other and things could get hot.
@Charles: a kind of drill CNC.
@Gord: I am very pleasure with the motors, wind sound is great. I have not tested out the thrust. I am only using it with 4S as the manual.
How do you like the motors? I am using MT2814 710KV, they weigh 120g. I driven them at 5S generating 2500g thrust with 13x6.5 props! Ran smooth and absolutely cool. Occasionally, one of the motors rings when accelerated.
12x4.5 but this is really not good enough. This is not balance well. I wish APC but there is not any store here in Vietnam selling it
what props are these ?
not in rctiger, it is in http://www.rctigermotor.com/list.php?catid=55. My model is MT3506-650Kv
You must contact directly them to get the price.
I remembered there is some site selling them, but it is expensive...
btw .. nice hexa.
1
2
of 2 Next
