Not all of the adventures that CanberraUAV have with experimental aircraft go as well as we might hope. This is the story of our recent build of a large QuadPlane and how the flight ended in a crash.
As part of our efforts in developing aircraft for the Outback Challenge 2016 competition CanberraUAV has been building both large helicopters and large QuadPlanes. The competition calls for a fast, long range VTOL aircraft, and those two airframe types are the obvious contenders.
This particular QuadPlane was the first that we've built that is of the size and endurance that we thought it would easily handle the OBC mission. We based it on the aircraft we used to win the OBC'2014 competition, a 2.7m wingspan VQ Porter with a 35cc DLE35 petrol engine. This is the type of aircraft you commonly see at RC flying clubs for people who want to fly larger scale civilian aircraft. It flies well and the fuselage and is easy to work on with plenty of room for additional payloads.
VQ Porter QuadPlane Build
The base airframe has a typical takeoff weight of a bit over 7kg. In the configuration we used in the 2014 competition it weighed over 11kg as we had a lot of extra equipment onboard like long range radios, the bottle drop system and onboard computers, plus lots of fuel. When rebuilt as a QuadPlane it weighed around 15kg, which is really stretching the base airframe to close to its limits.
To convert the porter to a QuadPlane we started by glueing 300x100 1mm thick carbon fibre sheets to the under-surface of the wings, and added 800x20x20 square section carbon fibre tubes as motor arms. This basic design was inspired by what Sander did for his QuadRanger build.
in the above image you can see the CF sheet and the CF tubes being glued to the wing. We used silicon sealant between the sheet and the wing, and epoxy for gluing the two 800mm tubes together and attaching them to the wing. This worked really well and we will be using it again.
For the batteries of the quad part of the plane we initially thought we'd put them in the fuselage as that is the easiest way to do the build, but after some further thought we ended up putting them out on the wings:
They are held on using velcro and cup-hooks epoxied to the CF sheet and spars, with rubber bands for securing them. That works really well and we will also be using it again.
The reason for the change to wing mounted batteries is twofold. The first is concerns of induction on the long wires needed in such a big plane leading to the ESCs being damaged (see for example http://www.rcgroups.com/forums/showthread.php?t=952523&highlight=engin+wire). The second is that we think the weight being out on the wings will reduce the stress on the wing root when doing turns in fixed wing mode.
We used 4S 5Ah 65C batteries in a 2S 2P arrangement, giving us 10Ah of 8S in total to the ESCs. We didn't cross-couple the batteries between left and right side, although we may do so in future builds.
For quad motors we used NTM Prop Drive 50-60 motors at 380kV. That is overkill really, but we wanted this plane to stay steady while hovering 25 knot winds, and for that you need a pretty high power to weight ratio to overcome the wind on the big wings. It certainly worked, flying this 15kg QuadPlane did not feel cumbersome at all. The plane responded very quickly to the sticks despite its size.
We wired it with 10AWG wire, which helped keep the voltage drop down, and tried to keep the battery cables short. Soldering lots of 10AWG connectors is a pain, but worth it. We mostly used 4mm bullets, with some HXT-4mm for the battery connectors. The Y connections needed to split the 8S across two ESCs was done with direct spliced solder connections.
For the ESCs we used RotorStar 120A HV. It seemed a good choice as it had plenty of headroom over the expected 30A hover current per motor, and 75A full throttle current. This ESC was our only major regret in the build, for reasons which will become clear later.
For props we used APC 18x5.5 propellers, largely because they are quite cheap and are big enough to be efficient, while not being too unwieldy in the build.
For fixed wing flight we didn't change anything over the setup we used for OBC'2014, apart from losing the ability to use the flaps due to the position of the quad arms. A VTOL aircraft doesn't really need flaps though, so it was no big loss. We expected the 35cc petrol engine would pull the plane along fine with our usual 20x10 prop.
We did reduce the maximum bank angle allowed in fixed wing flight, down from 55 degrees to 45 degrees. The aim was to keep the wing loading in reasonable limits in turns given we were pushing the airframe well beyond the normal flying weight. This worked out really well, with no signs of stress during fixed wing flight.
Test flights
The first test flight went fine. It was just a short hover test, with a nervous pilot (me!) at the sticks. I hadn't flown such a big quadcopter before (it is 15kg takeoff weight) and I muffed up the landing when I realised I should try and land off the runway to keep out of the way of other aircraft using the strip. I tried to reposition a few feet while landing and it landed heavier than it should have. No damage to anything except my pride.
The logs showed it was flying perfectly. Our initial guess of 0.5 for roll and pitch gains worked great, with the desired and achieved attitude matching far better than I ever expected to see in an aircraft of this type. The feel on the sticks was great too - it really responded well. That is what comes from having 10kW of power in an aircraft.
The build was meant to have a sustained hover time of around 4 minutes (using ecalc), and the battery we actually used for the flight showed we were doing a fair bit better than we predicted. A QuadPlane doesn't need much hover time. For a one hour mission for OBC'2016 we reckon we need less than 2 minutes of VTOL flight, so 4 minutes is lots of safety margin.
Unfortunately the second test flight didn't go so well. It started off perfectly, with a great vertical takeoff, and a perfect transition to forward flight as the petrol engine engaged.
The plane was then flown for a bit in FBWA mode, and it responded beautifully. After that we switched to full auto and it flew the mission without any problems. It did run the throttle on the petrol engine at almost full throttle the entire time, as we were aiming for 28m/s and it was struggling a bit with the drag of the quad motors and the extra weight, but the tuning was great and we were already celebrating as we started the landing run.
The transition back to hover mode also went really well, with none of the issues we thought we might have had. Then during the descent for landing the rear left motor stopped, and we once again proved that a quadcopter doesn't fly well on 3 motors.
Unfortunately there wasn't time to switch back to fixed wing flight and the plane came down hard nose first. Rather a sad moment for the CanberraUAV team as this was the aircraft that had won the OBC for us in 2014. It was hard to see it in so many pieces.
We looked at the logs to try to see what had happened and Peter immediately noticed the tell tale sign of motor failure (one PWM channel going to maximum and staying there). We then looked carefully at the motors and ESCs, and after initially suspecting a cabling issue we found the cause was a burnt out ESC:
The middle FET is dead and shows burn marks. Tests later showed the FETs on either side in the same row were also dead. This was a surprise to us as the ESC was so over spec for our setup. We did discover one possible contributing cause:
that red quality control sticker is placed over the FET on the other side of the board from the dead one, and the design of the ESC is such that the heat from the dead FET has to travel via that covered FET to the heatsink. The sticker was between the FET and the heatsink, preventing heat from getting out.
All we can say for certain is the ESC failed though, so of course we started to think about motor redundancy. We're building two more large QuadPlanes now, one of them based on an OctaQuad design, in an X8 configuration with the same base airframe (a spare VQ Porter 2.7m that we had built for OBC'2014). The ArduPilot QuadPlane code already supports octa configs (along with hexa and several others). For this build we're using T-Motor MT3520-11 400kV motors, and will probably use t-motor ESCs. We will also still use the 18x5.5 props, just more of them!
Strangely enough, the better power to weight ratio of the t-motor motors means the new octa X8 build will be a bit lighter than the quad build. We're hoping it will come in at around 13.7kg, which will help reduce the load on the forward motor for fixed wing flight.
Many thanks to everyone involved in building this plane, and especially to Grant Morphett for all his building work and Jack Pittar for lots of good advice.
Building and flying a large QuadPlane has been a lot of fun, and we've learnt a lot. I hope to do a blog post of a more successful flight of our next QuadPlane creation soon!
It looks so good to see you flying Tridge ! Thanks for sharing here.
Ouch. That brings back memories of the balsa RC days.
Anyway, that's a hard lesson to learn to test, inspect, and build things as if your life would depend on it.
E.g.: stress test ESCs and motors on the ground first way beyond the expected stress they'll receive in flight etc.
Look at the way the batteries are hanging on the wing: If one of those plastic clips break or the elastic breaks, then the batteries gone, followed by the plane. Rubbery velcro battery ties with anti-slip padding on the wing is much safer.
I wouldn't opt for an X8 setup though, because of the added drag and points of failure, even though there's some redundancy. A thoroughly tried and stress tested X4 setup is imho the best tradeoff.
Hi Tridge That's really sad to see and hear... :-(
I would have hoped the 2014 OBC Porter would have been hanging on the trophy wall for historic purposes. I hope it can be restored for that at least. In regards to the incident, although it was caused by the ESC failure, I'm wondering what sort of amp draw you were seeing on the rear motors when it happened. Did you have any current monitoring onboard from which this could be deduced?
From my armchair "perspective" and your comments I think the tail of the aircraft might of been a part of the issue whilst "reversing" that caused the ESC to be overloaded. What were the wind conditions at the time? I'm thinking that maybe the rearward quad pitch to move the quadplane backwards also leads to the tail and wing producing negative lift which in turn forces the rear motors to increase RPM to produce more lift. The quad is fighting the plane airfoils as well as trying to keep it stable. This is something we discussed on the ardupilot/quadplane thread where I suggested the quadplane only be allowed to move laterally (within reason) using the forward propeller, so that the airfoils can only assist in creating lift, and not create a down force and a regressive loop the quad motors have to overcome.
Do you think this could have been a part of the reason for the ESC failure? If not do you intend to integrate some pitch/roll limitations for quadplanes in quad flight to stop this from happening?
Regards JB
thank you for sharing. I have a question : we are (trying) to build reliable quadcopters for auto mission (like 5 km mission) done all around the year, few times a day. Right now, we have very few problems of reliability but I was wondering if it could be wise to "burn" motors and ESC fews hours before putting the quad on the market. As hobby grade motors, we do not have much informations about TBO but we use to change motors and ESC after 100 hours of flight. Any advice about quality control before flying ? thank you
that red quality control sticker is placed over the FET on the other side of the board from the dead one, and the design of the ESC is such that the heat from the dead FET has to travel via that covered FET to the heatsink. The sticker was between the FET and the heatsink, preventing heat from getting out." I buy tens of IR controlled RGB LED PWM controllers with burn out FET. Building 50V solar panel chargers I use Step-Down DC/DC converter and current is limited to 2A, increased to 3A when radiator is affixed to FET. I didn't notice the heatsink on the images but why not to glue individual radiators and let free air flow to cool radiators down or use fan to support enforced cooling ?
Ok, QC sticker is manufacturer's fault, so you can easily get money back claiming damages.
Please attach image of heatsink.
DJI is using power draw limit on Li-Po batteries not to burn them but I still see no temperature sensor built-in by default into Li-Po battery packs to prevent overcharging and heavy power draw.
Hey @Tridge,
That's a very nice build, too bad it failed on the ESC. But it's nice to know quadplanes perform well, even when you scale them up.
It's nice to have been of help with my QuadRanger build log.
-sander
@Andrew Wow, that is what pioneering has. Congratulations!
Maybe accounting for TAS, AoA and SS in QHOVER controller could help you :)
@DBX, the transition before the crash was under pilot control. The pilot switched to QHOVER mode and let the plane naturally come to a stop, then the pilot started backing up a bit to get to a better landing point. The backing up wasn't perfect, but the logs show the plane was doing what was requested of it until the rear left engine failed. After that it tried desperately to retain stability but didn't have a chance.
@Andrew Tridgell Amazingly well executed. It is far better to do what you said.
I thought it was motors saturation in the video due to yaw channel saturation. If it is yaw rate controlled: Why was it having yaw-roll coupled perturbations then?
I am glad to see you are using as well simulation for validating the controller! :)
Good luck for the next quadplane tests!
4
5
6
7
8
of 8 Next
