Frequencies: 8 channels from 5.645 to 5.945 GHz
Channels: CH1 5705 CH2 5685 CH3 5665 CH4 5645 CH5 5885 CH6 5905 CH7 5925 CH8 5945
Power: 2000mW (33dB +-1dB) of certified output power
Input Voltage: 7-24V DC, 2-6 cells battery
Cooling System: whole body heat sink and cooling fan
Channel Switching: channel button and channel display
Antenna: RP-SMA female 50 ohm connector
Size: 62mm x 42mm x 20mm
Weight: 37g
I always feel like I am being super negative on RF stuff, but I work at a wireless company and have opinions - okay now that is out of the way... there are two big things to remember here 2000 mW is actually not that much better than 600 W (it seems like it but it is not) and the quality of the TX and RX chain is dramatically more important than PA power (PA is Power Amplifier). So in RF we typically dont use watts, they are clumsy when dealing with big numbers (remember that many radios are sensitive to .0000000001 mW and that is just ridiculous to write so we use db so that we can write things like -90dBm instead. So lets look at transmitters:
200 mW = 23 dBm
600 mW = 27.7 dBm
2000 mW = 33 dBm
To get 2x the range you need to add 6dBm to TX power or 4X the power in mW which is consistent with the inverse square rule (actually RF uses the Friis equation but inverse square is good enough for the math we are doing). So a 2000 mW radio at best gets you less than 2x the range of a 600 mW Tx which gets you less than 2x the range of a 200 mW.
Looking at weight, power consumption and cost, it is more worthwhile to buy a high quality, low power radio with a good antenna than a honkin' tx.
If anybody is wondering I own a 200mW transmitter with nice antennas :)
goodluckbuy has a lot of storefronts selling for them, but they are the actual supplier.
Weird setup, but I have always rec'd the stuff, -just takes a while, like any purchase from china.
ps: I bought from good uckbuy but I think these are the same people
There are some alternatives here, cheap with free shipping. I have no idea about the quality of these items but I have purchased other equipment from these people and it was good quality/worked well. Hopefully this equipment is as good as the stuff from HobbyKing which in my experience is excellent. Do need to understand the "radio" laws of each country before buying any of these items.
http://www.uuustore.com/fpv-av-tx-and-rx-c-21.html
Free shipping 5.8G 2000mw 12ch Wireless AV Transmitter and Receiver for FPV
Free shipping Boscam 5.8G 1W 1000MW Video Audio Transmitter TX 5KM with 5.8GHz Reciever for FPV system
Free shipping Boscam 5.8G 500mW pulg and play system specially designed for FPV
Free shipping 5.8G 400MW 8CH Wireless Video and Audio transmitter and Receiver for FPV TX RX
Free shipping BOSCAM 5.8G 200mW pulg and play system specially designed for FPV
Free shipping BOSCAM RC305 CH8 5.8GHz Pocket Size High Sensitivity RC305 Receiver
Free shipping Boscam RC805 5.8G Wireless AV Receiver for FPV
Free Shipping BOSCAM 5.8G 2W 2000mw 12Ch Wireless Audio Video Transmitter AV Tx
Free Shipping Boscam 5.8ghz 1000mw 8CH Transmitter AV Module with long-distance TX for FPV
Free Shipping BOSCAME FPV 5.8G 500mW Video Audio Transmitter 4KM for 5.8Ghz RX 28dBm TS352
Free Shipping BOSCAME RC FPV 5.8G 400MW Video Audio A/V Transmitter TS353 TX 4KM for 5.8GHz Receiver
Free Shipping Boscam 5.8G 200mW Tx transmitter for FPV
This is just plain overkill blasting of the airwaves.
To prove his new antenna designs, Alex (IBCrazy) has been running really low powered video TXs... like only a tenth of what the rest of us run. (I don't recall the exact power he mentions and can't find the threads right now)
2 watts @ microwave freqs ? Wow!
...Ah well, I've fathered all the kids I want already, but I still plan on using my coconut for a few more years.
I guess that tin-foil hat would come in handy now.
Yeah, I saw this and, I'm not so sure that it's a great idea. How far do you want to fly?
A well set up 200mW transmitter is capable of range over 1km, I've heard of people even going 20km.
This high power system is just going to spray radiation everywhere. If you don't have an effective antenna system, you still won't get long range, as it will be creating as much noise as it is creating signal.
Well in the USA you need a amateur radio (HAM) license to use equipment like this legally. I believe the max without this FCC license is in the 25mW category. I would highly recommend getting a ham license if you plan on doing any FPV... since the FCC no longer has the Morse code requirement it is a lot easier. Morse code requirement existed when I got mine but even then it wasn't bad. Since the majority of the license is antennas and broadcast rules and regulations it is good to know.. plus you can use equipment like this legally.
If I think about how the maximum output in (most of) Europe is limited to 25mW... wow...
I wonder if the 2000mw will not interfere with the APM sensor? Will it not be better to wrap this unit in a piece of foil.
1
2
3
of 3 Next
