Carbon Fibre Brushless Gimbal for NEX and smaller.
3689526581?profile=original
I now have an RCTimer OpenSource BGC board ("Martinez") and a couple of LD-Power Gimbal Motors which are large enough for an NEX or smaller.  I looked over a number of BGC frames for sale but they all seem to incorporate metal or glass fibre, both of which do not have the same strength and low weight of carbon fibre.  Based on the connection system I had used on the first CF gimbal I built from scratch (servo based), I have come up with this design with the size needed for a Sony NEX and the adjust-ability to balance for any camera of that size or smaller to maintain roll balance.  Also, the base plate the camera sits on is deep enough to move the camera back to balance the weight on the pitch axis due to the size of the NEX lenses.
Once I have hand crafted this design I'll post some video.  From there, if there is enough interest I may get a batch of these laser cut and put them up for sale.  Roughly $30 of 2mm CF board for this and whatever the rate is for laser cutting.
This specific design is for the LD-Power GM4008-57 motors which are 45mm in diameter, 21mm in depth and 85g each.  Still need to work out how many poles these motors have to be able to set up the firmware correctly.  If anyone knows please let me know?  I was planning on using the smaller LD-Power 2208 gimbal motor which was 39g or so but the eBay seller had the wrong picture and weight in the listing.
3689526853?profile=original
  • Updated design with corner clips to increase rigidity and a new attachment method with rubber grommets around the two 12mm CF landing gear booms to help absorb vibrations.
    3692736146?profile=original
    3692736245?profile=original
  • 3692736124?profile=original
  • Slowly getting there with the prototype...3692736271?profile=original
  • Thickness is a large factor to the rigidity of the CF.  I find the cheap CF 12mm booms with a wafer thin wall that you get all over eBay are strong to some degree but do introduce flex. If the motor / prop buzzing on the end is not close to perfectly balanced you end up with all hexacopter arms wiggling with the vibes it carries through the whole craft.  I remember seeing that on my T-Rex 450 years ago when I switched to a CF boom (real not painted AL).  If you have managed to track down decent 1mm wall tubes then they should be very hard to bend.  And I think you meant >1mm not <1mm.
    However, in this case I find the 2mm board I use to be very solid.  It won't be hanging a spinning prop off it - if the craft that the gimbal is hanging off already has vibes then without any vibe isolation between the gimbal and the craft you will see the wobbles on the video.  Each method of attachment for the gimbal will be different due to the many variances of craft out there so what I design as an attachment point will be very specific to the hexacopter I designed.  Either way I will have some form of vibration isolation as the gyro that comes with the BGC won't like vibes.
    Sorry for the off topic, but it's kinda related to gimbal construction in general.
    R, your CF must be different from what I have. Comparing a CF and Alu plate there is no competition. CF wins every time. Especially if the plates are <1mm thick. Same goes for the tubes I have tested (22/25mm). How thick was the CF in your tubes? Mine are about 1mm.
  • I'll do the smaller GoPro design once I perfect this one. Should be a matter of scaling it down.
    Requests for quotes to cut CF are out so I should get an idea what I could sell these for.
  • Wow, how did my blog post diverge into CF on 450 heli's? Back to my design, I have found that the 2mm CF boards at the dimensions of this design to be very solid and most importantly light, regardless of what it looks like. If I'm going to slap a Sony NEX on a 1kg frame, trimming extra weight off is going to be high on my list.
    Takes a good amount of force to bend them. I may end up with AL for the connection between the gimbal and the multirotor if the rectangular CF tube introduces vibrations, but I think it should be fine. Hopefully the CF board will arrive soon so I can get cracking on it.
  • Count me in as well
  • Hi Robert,
    Nice welded frame, the 4in 1 ESCs seem like a good idea too, although I's guess that isn't where you'll be mounting them.
    That looks like 1" or larger square tube and the inner motors have 3 places where it interferes with the thrust, probably unavoidable.
    It will be interesting to see how lift varies on your 4 inner motors versus your outer motors.
    I'd actually really like to know that.
    Nice welds on that thin tubing.
  • Yeah, I felt a big ripped off.  I mean... why not tell us exactly what we're getting?  I wouldn't have paid extra.
    On my 450, I tried a real CF boom tube, and it was a disaster.  Horrible, horrible vibrations.  I mean, the tail lit up like a paint shaker.  The heli was shaking itself apart.  I fiddled with it for a bit, not realizing the boom was the problem.  Then I stuck the aluminum tube back on, and boom, perfect.
    Not saying carbon fiber is no good.  It's great in the right application.  But 1/16" CF plate is not strong in bending.  I think the problem is that the fibers are only strong in tension.  They are not strong in bending.  And a thin, woven CF plate, basically have the strands in an accordion pattern, if you cross section the plate.  None of the strands are in pure tension when you try to bend the plate. They are all being bent again, like an accordion. Or, consider the stiffness of a Slinky, compared to a solid steel tube of the same dimensions.  That's what you're getting.
    I don't have a good answer for why the CF tubes are also flexible.  But I suspect it's because they also have not enough CF by volume.  Too much epoxy, and then a clear coat so they're pretty.
