Cheap RC Helicopter Controlled via Motion Capture
Autonomous Helicopter from M W on Vimeo.
Recently we've seen a couple of really interesting university projects where quadcopters are controlled in motion capture stages. The video above demonstrates my progress while working at the USC Institute for Creative Technologies this summer over the course of about 2-3 weeks, to show that even cheap models can be controlled in motion capture stages, and some progress toward innovative control mechanisms (following a gloved hand).
Technical:
The model is a HorizonHobby: Blade CX2 RTF Electric Coaxial Micro Helicopter controlled via a Spektrum DX5e receiving servo signals through an Endurance RC PCTx from a PC computer. The software running on the computer consists of a VRPN (Virtual Reality Peripheral Network) middle wear program that takes data from a Phase Space Motion Capture Stage OWL Server and outputs clean model position data (x,y,z and heading) to a VR engine written to Dr. Evan Suma. The model is controlled by 4 PID loops, one each for the X,Y,Z, and heading variables and includes adjustable clamps, offsets, ramps, throws, trims, and other functionality to make it easier to tune and adjust the control loops. All of these values are adjusted easily by editing a text document that is read-in to the software every time it is executed, to prevent a recompilation whenever any values need to be adjusted (Often when manually tuning a PID loop!). Also, included in the control code is a trapezoidal function that smooths
deltas to the PID loops to prevent shocks to the control system (thanks to Marc Bolas for that suggestion!).
The PID outputs are then sent over a USB Human Interface Device to the PCTx, converted to PWM and PPM signals, sent to the TX, through the RX and eventually arrive at the servos and motor controller and make the helicopter move as desired.
The oscillations you will see in the video footage indicate that the PID loops are NOT critically damped (ie they need to be better tuned). But I believe that for two weeks of work that's pretty good performance for an inexpensive single rotor helicopter.
Hope you enjoy!
P.S. With luck code and a build log may be released soon, stay tuned!
  • Ryan,
    Thanks for the advice! Your right, having all that processing onboard is the way to go. This particular setup didn't have anything onboard except the standard RC equipment for the helicopter and a driver "puck" for the LED's. The reason I did it that way was to tie-in quickly with their motion capture stage and allow them to control most airframes with minimal modification.
    And yes "At Least Were Not Airforce!" lol - Nothing against Air Force though, just the Academy. :)
    Are you in flight school btw? I still have another year to go.
    "how they do things" meaning Kestrel autopilot GUI and control law layout etc. sorry I wasn't specific.
    Oh and I would throw in Go Navy, but I'll just drop the "At Least We are not Airforce!"
    Keep me posted!
    I'm not sure what your setup is, but the more you can offload the lower level flight controls such as altitude hold and attitde hold onto the autopilot the better. Keep the upper level navigation to external visual comp. If you try to do everything off board you will get to enjoy the wonderful world of latency! Great project! If you havn't already you should tag team with the guys using kestrel. They would love a controls guy who understands PID etc. Plus you could probably learn a ton from how they do things. I know I did. Good luck on finishing up if you havn't already
    USNA '08
    LTjg Beall USN
  • @Ryan,
    Impressive performance with such few components! Makes me think I almost over-engineered this one..
    @Gary, others,
    Thanks for the accolades!
    @Morli,
    Not a hijack at all, thanks for the posts, some really interesting ideas and other work! A note about a safety feature in my design.. One advantage of my setup was that in order for computer control to pass through to the helicopter someone had to physically hold back the trainer switch on the Spektrum radio as the computer was inputing through the buddy interface. More times than I care to admit I had to release that switch and either kill the helicopter or take control back using the TX and try to save the model manually. I know you can simply modify the switch but in its present configuration it turned out to be a valuable safety feature!
    Better to be safe than sorry.
    Wow! fmkit has very professional radio modifications that I will attempt, Off to Goodwill for some recycled` Midland radios and 2 sets of fmkit Wi Nunchuck chip kits will be ordered as well. Nice pan & tilt stabilizer may be released soon too.
    Nice one, interesting control idea, the method for getting airframes around a point intuitively and without lots of training will probably take up lots of time in lots of minds over the next year or two.
    Navy's Blade CX doesn't require proficiency in keeping other hand in pocket.
