Power: | On |
Stat: | Flashing in sequence |
GPS Lock: | Flashing in sequence |
MUX: | Off unless a RC receiver channel is connected to CTRL pins and that channel is toggled on |
Mode: | Off |
Power: | On |
Stat: | On |
GPS Lock: | Off |
Mode: | Off |
Power: | On |
Stat: | On |
GPS Lock: | Off |
Mode: | Off |
GPS LED: | On |
Power: | On |
Stat: | Blinking |
GPS Lock: | On |
Mode: | Off |
GPS LED: | Blinking |
Power: | On |
Stat: | Will blink twice as GPS is programmed into binary mode, then blink steadily |
GPS Lock: | Flashing while it attempts to aquire a lock; solid afterwards |
MUX: | Will turn on briefly during boot, then stay off |
Mode: | Off |
GPS LED: | Off |
Power: | On |
Stat: | Off |
MUX: | On |
Mode: | On |
GPS LED: | Off |
Power: | On |
Stat: | Off |
MUX: | On |
Mode: | Off |
GPS LED: | Off |
The voltage reg gets very hot and it seems to trip out, notice the power led going out?
The battery is a 900mah 7.4v Lipo
IMGP0004.AVI
IMGP0005.AVI
It seems there is a problem
1. I cannot get my leds to look as per the tables
2. although its a sirf3 GPS module (BR-355) I dont know if its going into binary mode
3. Is the board faulty (have I messed something up when soldering in the pins)?
4. Am I over driving it with 7.4v, I was hoping to use a 200 or 360mah 7.4v lipo to power it, should I be thinking 4.8v?
I know some of these questions should be in other sections but it seems to relate to the led behavior
Ronnie
ArduPilot 2.0
program loaded nothing else
IMGP0001.AVI
GPS now connected
IMGP0002.AVI
Now switched channel connected and toggled 2 times
IMGP0003.AVI
Ronnie
ArduPilot 1.0
IMGP0001.AVI
GPS now connected
IMGP0002.AVI
IMGP0003.AVI
Ronnie
IMGP0001.AVI
Hope that works
Power = red led = on
Mux = not on
Mode = not on
GPS = blue led = on and sequenced (ie follows same pattern as Status)
Status = yellow led = on (leads GPS led about 6 flashes then stays on for about 1/2 sec)
Does everything look ok so far?
Waiting for FTDI breakout to arrive
Ronnie
