Current (and Airspeed) for $1.45
G16976B.jpg?width=130
This is a Current (And Airspeed) Sensor for $1.45.
I raised this question a while back, and was reminded again by the Post below which asks how to stuff all of this into a small box. (Beautiful Glider)
Small planes should remains a primal focus because they reduce the real and regulatory risks and allow broader participation in more fields/parks, etc...
So I'm offering a size reducing part - add a current sensor in exchange for the whole pitot/airpressure spaghetti.
The Airspeed theory is simple - at a given RPM, power consumption is proportional to airspeed, The faster the plane, the less the motor consumes to turn the prop. One can either detect the rpm, or determine that ESC's are essentially RPM = Throttle. Then a bit of data collecting will show the relationship.
http://www.goldmine-elec-products.com/prodinfo.asp?number=G16976
  • I certainly like the thinking, but I'm pretty sure it's much more complicated than that.  However, as you say, the data will (or will not) show the relationship :)
    "at a given RPM, power consumption is proportional to airspeed" - only if you are also accounting for the orientation of the aircraft relative to gravity as well as the drag force that is dependent on a multitude of factors that have non-linear relationships.
    Simple example: an aircraft that is fully vertical will be exerting a large amount of power even though the airspeed is zero.
