3689606200?profile=original
Last academic year at KU Leuven, we designed, built and test flown a VTOL UAV: the VertiKul. During this project we gratefully made use of the info and support of the DIY Drones community and therefore we would like to share our results on this project.
The VertiKul is designed for automated aerial transport of small packages and is optimized for maximum range and payload capability. The innovative design makes use of the benefits of both multi-rotors and fixed-wing airplanes. For take-off and landing, the VertiKul hovers like a quadrotor and for forward flight, the VertiKul pitches 90° and flies like an airplane.3689606095?profile=originalIn airplane mode, the attitude is also controlled by differential thrust of the motors. Therefore, no additional control surfaces are required, reducing the number of moving parts, risk of failure and maintenance cost. The structure is made out of three carbon fiber tubes in a ‘H-configuration’ allowing an easy accessible space for a 10x15x20 cm package of 1kg. The tubes are connected using laser cut multiplex wood and wings are constructed using a polystyrene-balsa sandwich structure, covered with Oracover. For a good directional stability, the wings are slightly swept-back and winglets, that also help reducing the induced drag, are added. Since the wings introduce a high moment of inertia and strong moments because of wind around the yaw-axis, the propellers are tilted 10° to improve the yaw control.
Because of the two different flight modes and the transition in between, a new control strategy is needed. This strategy contains three levels. The first level, or low level, is the angular rate control as in “Acro mode”. Because of the -90° pitch in forward flight, it becomes hard for a human pilot to control the VertiKul since a roll command results in a yawing motion and a yaw command makes the vehicle roll (in counter-intuitive direction, yaw to the left results in roll to the right!). To make the control more intuitive, a mid-level controller is designed around the angular rate controller. This controller acts as “Stabilize mode” when the VertiKul is in hover and makes an automatic transition to forward flight when a switch is turned on the transmitter. The transition to forward flight takes around 5 seconds and gradually decreases the pitch angle to build up the speed required for enough lift of the wing in forward flight. Any input from the pilot is ignored during this phase.  A quaternion representation was required in order to avoid the ‘Gimbal lock’. In forward flight, the pilot inputs are only the desired altitude and heading, making it easy to fly by inexperienced pilots. Finally, the high-level controller generates a trajectory between two base stations and commands flight mode, altitude and heading to the mid-level controller.
3689606224?profile=original
In order to have a fully autonomous system, we also developed a docking system. The system includes an optical precision lading system, based on a PX4FLOW unit and a docking station at which a package or battery can be swapped. The VertiKul starts from one docking station with a fully charged battery and a package of 1 kg and then flies to its destination, 30km further, based on GPS. Once arrived at location, the VertiKul makes a precision landing on the docking station at that location. The battery is replaced with a full one and a new package is loaded so that the VertiKul can continue to its next destination.
The PX4FLOW camera we use for this autonomous precision landing is re-programmed in order to detect the center of the marker on the docking station and sends these coordinates to the autopilot on the VertiKul. Based on the altitude, roll and pitch angle of the VertiKul, the position of the marker is calculated and a position controller navigates the VertiKul to the landing spot. In order to be able to land at night, the marker is illuminated by leds under the surface of the translucent marker.
Check out the video here: http://youtu.be/omaxgFVDUWg
We haven’t yet been able to test the full performance of the VertiKul because of the limited test area where we can fly. During test flights we experienced a lot of influence of the wind on the big wings, making automatic landings very hard. Also the battery and package swap is not yet automated, leaving us with enough work to continue this project.
3689606263?profile=original
  • 100KM
    You are right, there is not much information around concerning performance of multi-rotors in forward flight. I see two reasons for this:
    - Most multirotors are used for hover flight. Forward flight is not a typical flight pattern, especially not fast or far forward flight.
    - Multirotors perform badly in forward flight. The rotors are not designed for that. The fuselage often isn't either. The multirotor guys don't like to admit and document that.
    To me it is clear that a conventional helicopter performs significantly better in forward flight than a multirotor. I don't know any scientific or field proven numbers. I guess there must be a difference of factor two or so.
  • You are right about safety, I rather have 4 small propellers than one big. To improve landing and take-off by choosing for a conventional helicopter, I would think going to a conventional multi-rotor improves these qualities even further. But I suppose a conventional helicopter (same mass, dimensions ) can fly further/longer/faster than a multi-rotor? There is actually a big lack of information about multi-rotors in forward flight (speed, power consumption, drag, flight behaviour ).
  • 100KM
    A well designed VTOL will fly faster and further than a conventional helicopter. E.g. the Osprey flies about 50% faster and 50% longer therefore about double the distance of a comparable helicopter. But it suffers serious stability problems in hover and is complex and expensive.
    You want to fly 30km at 60km/h, therefore have a flight time of 30min.  I am sure a conventional helicopter can be easily designed for 30min flight time at 40km/h. That is a bit less, but might be overcompensated by higher stability to wind at landing. Keep in mind that a well designed electric model helicopter can fly over an hour, I think the world record is almost two hours. Most RC helicopters only fly 10-15 minutes because they are designed for 3D flight. A a sky crane with appropriate blades or even a funcopter already fly significantly longer and can carry heavy loads.
    You are right, the swash plate mechanics are quite complex. But they are extremely mature, very reliable, hardly need any maintenance, mass produced and cheap. Might be a down side of a conventional helicopter, but from my point of view not very critical.
    Another issue comparing quadrocopters and helicopters is safety. The rotating blades of a helicopter are quite dangerous. The propellers of a quadrocopter a bit less, especially when you have a protecting frame around them, like many quadrocopters have. But for VertiKul a protection frame a not ideal as it deteriorates flight performance significatly.
  • I'm not sure whether a conventional helicopter has a better performance in carrying a payload of 1kg at a speed of around 60 km/h. A helicopter scores definitely lower in terms of complexity, price and maintenance because of the swash plate mechanics.
    It would be very interesting to compare the performance of the VertiKul with those of a conventional (electric, to keep it quiet and environmental friendly ) helicopter. Does anyone know such a helicopter?
  • 100KM
    I think a steep or ideally vertical approach is valuable for your application. For parcel delivery you will typically land in urban areas with lots of obstacles, not in wide open areas. Therefore I like your idea of the deep stall into the wind. The strategy could be:
    - Circle over the landing spot at 30m AGL to determine the wind direction and strength
    - Calculate the optimal approach path for the deep stall
    - Perform the deep stall into the wind from 30m to 3m AGL
    - At 3m AGL over the landing spot transition to hover
    - Descend slowly in hover mode to the landing spot
    This would be a real innovation, I don't think anyone has done this before!
    One could argue that a standard helicopter could perform such a landing even better, being less prone to wind, perfectely maneuverable and maybe even doing it with no power and no propwash problems in autorotation. But I guess you want to stick to your VTOL concept ...
  • Reto, we didn't bump into this problem yet, we always descent slowly ( like any other multi-rotor ). If we want to minimize the time in " quadrotor mode " we'll have to descent faster. A solution might be a descent with the wing in deep stall and the nose pointing to the wind direction?
  • MR60
    Hi guys,
    Very cool innovation & research topics!
    Sometimes, I'm proud to be Belgian :)
  • 100KM
    When descending in hover mode the wing gets reverse airflow. If the plane wants to correct its flight path to the front, it will pitch to the front, like a quadrocopter does. But the wing will create a force to the rear. Same in the opposite direction and also for bank (roll). If you descend very slowly, the wing effect es weak, the quadrocopter effect dominates and the control works. If you descend fast, the wing effect dominates, you lose control or even get control reversal and crash.
    The guys of QuadShot "solved" this problem by instructing pilots not to descend fast in hover mode, but to descend in cruise mode, transition at low altitude to hover mode and then descend very slowly. Not very pretty. It would be nice to be able to transit at safe altitude, say 30 meters AGL and then descend fast.
    This is a characteristic of VTOL planes in this configuration, therefore also applies for VertiKUL. Do you have a strategy to handle this?
    Additionally you have the effect of descending into your own propwash. Any quadrocopter or helicopter suffers this effect. For safety reasons no full scale helicopter pilot therefore ever descends fast vertically. But from my experience for model quadrocopters this is not a major issue and rarely causes crashes.
  • 100KM
    The Wingcopter should handle wind better having the airframe horizontal when landing. Just point the nose in the wind and you should be fine. I am also interested to learn about their real flight experience.
    Another issue to consider is descend characteristics in hover mode. The QuadShot has experienced quite some problems due to instability. The wing counteracts the quadrocopter in this flight phase. Ailerons make it even worse. The Wingcopter configuration should work better.
  • 100KM
    I like your approach "simple is beautiful". Simplicity is the silver bullet to reliability.
    In stabilized mode the QuadShot acts exactely same as you describe the VertiKUL. Both having a full feature autopilot on board they both fly even completely autonomously. The QuadShot is only difficult to fly in aerobatics mode.
    You might share some experience with the guys of Wingcopter. They have a pretty cool 3m composite prototype flying and also use APM.
