Hi there.
This being my first post and all please bear with me.
Having read through an number of posts on airframes for armature UAV's i'm left a bit baffled.
I do understand that some people are more into electronics and software than building airframes but i find it quite odd that a modified Easystar seems to be the "donor" plane of choice.
I know that the mods are endless and there's even a guy that writes about building and selling Easystar carbon fuselages here but from what i can tell the fuselage and the fact that ailerons are not standard
is the Achilles heel of the Easystar.
Obviously threes no reason to reinvent the wheel so i was thinking along the lines of combining the wings of something like a "BMI Arrow", "AXN Floater jet" or "Dynam Hawksky" (they are all Easystar type planes
but with ailerons) with the fuselage of something like "Penguin-B UAV" or "Team Javelin" which should basically result in a platform as stable as the Easystar but with a lot more room and freedom for payload placement.
Anyways... My point being (although a bit obscured). How about a joint venture. There's loads of brilliant people with tons of experience in here. Why not define a "standard" DIY Drone platform that will suit the majority of projects?
Please let me know you thoughts.
Lets get a list of requirements together and see what happens.
Kindest Regards
/Stig
To make a twin boom we would need to find a plan for a biggish aileron trainer wing and add a box to it at the correct measurements.
Deciding on what size that box is to be would cause the greatest argument!!
I just feel you should go farther then what’s been said here.
UAV design is based more on what manned aircraft look like then what really works beast and that bugs me. Why not go with a box wing design instead of the norm mid wing and tail design.
1) It gives you more wing area for a size of the crafts foot print, allowing it to be a smaller aircraft all around.
2) Having forward and aft wings smoothes out the pitching caused turbulent winds making a much more balanced craft.
3) The design gives you larger control surfaces.
4) It has naturally stronger wing structure.
I know I’m not anywere close to the norm on this site but it just makes more sense to use what works best instead of what people are used to.
There are lots of airframes and styles, and there will always be many. The best systems and accesssories (TX/RX, servos, ESC's, motors, Autopilots...) are those that can adapt to different models/setups/flying styles.
As you say theres a lot of vets here with a lot of experience, but do you think its fair to ask them all to go out and buy a standard airframe? (esp if its not what they're used to flying or what they want to fly)
And afterwards, say that we (as a community) shows there is a much higher demand for one specific model of RC plane. I think its reasonable to say we'll see a pretty good price hike as resellers catch on.
What do you mean by 'joint venture'? It sounds like instead of you going through and choosing an airframe and motors/etc, you get the vets here to do that and have them buy the same setup.
PS that pic looks a lot like Michigan's AUVSI carbon fiber beast.
I agree. Thank you for you kind invitation. I accept :)
Having read through a significant part of both threads and pondering on the reply's in this thread for a while i'm beginning to lean towards a "plug in" replacement fuselage for the EZ.
Also i can't help but notice from the other threads that these things can get out of hand pretty easily so i believe we should try to keep this as simple as possible.
It also seems to me that you already have some design thoughts and i'd be very interested in hearing them.
/Stig.
1
2
3
of 3 Next
