We are glad to announce that DJI Phantom 3 and Inspire 1 are now supported in UgCS desktop mission planning software. This works through our Android app UgCS for DJI available now on Google Play. The app connects to DJI Phantom 3 or Inspire 1 remote the same way DJI native app does. What is different is that, once your laptop and Android device are connected to the same network, your drone is automatically recognized in UgCS desktop mission planning software.
This enables you to use UgCS desktop mission planning functionality to its full extent on your Phantom 3 or Inspire 1.
This allows you to pre-plan automated missions from the comfort of your office without the need to even turn the vehicle on. Then, once you are out in the field, simply turn on the vehicle, upload the pre-made mission and fly. This saves you battery time and the hassle of setting everything up in the field.
UgCS works on Windows, Mac OS X and Ubuntu.
For more information and downloads visit www.ugcs.com
Hi, Jesse! You are indeed right, our Ubuntu version is unfortunately older than 2.9 because of a few technical problems. We expect to change it with 2.9.1 update. We don`t usually do compatibility tests of newest version of Android with older versions of UgCS. Did you try and run it and it refused to run, saying that the version of UgCS is too old? If so, we may have an older version of our Android app that is compatible with newest version of UgCS running on Ubuntu. In case you are interested in this, e-mail me at kristaps.brass@ugcs.com and I`ll try and sort it out for you!
I realize this is a fairly old post but is it possible to use UgCS on Ubuntu with the Phantom 3? I am asking because the UgCS Android App I downloaded says it needs UgCS 2.9 but the most recent Ubuntu download seems to be 2.8 pre-update 1
Dronin -
1. Once the drone connects, you should be automatically taken to the drone's location on the map. And if you move away, double click the name of the drone to center the drone on your camera.
2. The No-Fly-Zones around airports in UgCS are not cylindrical, they resemble a reverse cone, just like you described. The lower you are, the closer you are allowed to fly. If you lower the camera you will be able to see it better. Airport no-fly zones can be disabled in UgCS Pro.
Also - if only a part of your route is in the NFZ, UgCS will automatically place waypoints so that your drone will fly around the NFZ.
Best regards,
Kristaps
Inspire 1 and Phantom 3 support was introduced only in UgCS 2.6.
With DJI DataLink (900Mhz or 2.4GHz) UgCS supports A2, WKM, Naza-M v2, Phantom 2, Ace.
Justin, I'm sorry you're having this issue. A few things you could try:
1. Are you running the newest version of the app?
2. Try opening the app first before connecting the wire to your device
If this does not help, e-mail us at support@ugcs.com and we will work to solve the issue you're having.
Oh, I thought your software already worked with them? What changed?
