DroidPlanner 2.3.3 is out on Google Play Store. This release shouldn’t change much for the average user (just a couple of bug fixes), but it’s a huge improvement for developers.
The changes include (here is the full change log):
  • Support for Hybrid mode.
  • Logs upload to DroneShare (opt in)
  • Miscellaneous improvements on mission planning code.
  • A couple of bugfixes, for example making mode changes work with Hexacopters (and all other copter configurations)
  • Decoupling of drone-specific code from Android UI code
The last item means that all the code relating to the drone and mission state is in a separate library, and can be reused in other GCS applications (it could even be used as the base for a PC/MAC application).
About the first image:
The flight was planned with the new version of DroidPlanner and executed with an Iris. Some pre-planning was also needed to find out the correct path to take, and places to add delay waypoints.
The entire flight was made just using DP2, but with a safety pilot ready to take action. Here is the result:
Screenshot from 2014-05-10 13:25:54.png
Links:
Download here.
You can get support here.
Donate here.
Find some Frequently Asked Questions here.
And see the source here.
