3689681013?profile=original
Dear Community,
Drotek, French tech start-up is proud to release its L1 RTK GNSS ! RTK technology allows to enhance GNSS positioning and to go down to centimeter level precision.
We have seen a lot of RTK boards coming up. However we have witnessed no good integration for the UAV segment and no performance enhancement in difficult environments.
This is why we decided to develop a solution to cope with these issues. Drotek is specialized in electronic design for UAVs and has put all its expertise in designing this board, jointly with French National Center for Space Studies (CNES) and French Institute for Aeronautics and Space (ISAE).
What is RTK for?
RTK technology uses corrections from a second GNSS receiver (called “base”, the other mobile receiver is called “rover”) in order to correct errors that lead to meter level precision. It has been used for a long time by surveyors, but at a very high cost. Today we want to trivialize this technology.
Our two years spent on developing this product have led us to focus on several points, such as connectivity, signal quality, EMI, real-time, etc...
3689681034?profile=original
3689680842?profile=original
We have compared our system’s performance with dual frequency receivers (in blue, Rover : Septentrio AsteRx 3 L1/L2 + Novatel geodesic antenna in RTK with base Trimble NetR9 + TRM59800), and it is pretty astonishing!
3689681061?profile=original
RTK works well in clean open-sky environments, but we like to test our device in difficult scenarios. Urban canyon is stil a pipe dream, but some route on ground robot in medium-hard environment (buildings, trees…) gives pretty good results :
3689681163?profile=original
Comparison between single GPS (red) and RTK : have a look at the left side under the tree. Single position gets highly contaminated by multipath, whereas the big ground plane and the Tallysman antennas filter it quite well :
3689681127?profile=original
Comparison between RTK Drotek (orange) and another open-source RTK solution (yellow) :
3689681204?profile=original
Base correction data can be sent through serial port with 3DR Radio types but also through cabled or wireless Internet for those want to get rid of range limitations. All drivers and server programs are already in the board. The following table sums up the different possible ways of communication between rover and base.
3689681185?profile=original
We are currently developing LoRa based transmitters, hoping that these will fulfill our expectations (we are quite excited about them!). Coming soon.
We truly believe in open-source community, but this board has also been designed to work “as is”. All boards will be delivered flashed and ready-to-use, with really little configuration, mainly for non-advanced users who would wish to get to precision without spending too much time on understanding how it works. Our wiki will explain everything step-by-step, but will also provide support on using RTKLIB graphical tools for post-processing and analyzing data. Do not forget to check our Github, we will publish in it really soon!
All our boards are stamped “Made in France”, we pay a lot of attention to the devices we manufacture in our French factory. Our motto is open source and open hardware, we work this way and we will stay this way. We want sell the atoms not the bits.
The package will be available in our site for pre-ordering. The expected release date is in one month, with a price of 699 € excluding VAT.
Our website is currently being redesigned, hope you will appreciate the new one! There will be plenty of content on how to use all the devices we manufacture, from little sensors to big boards!
Some additional exciting results :
This picture depicts the precision you can expect with good conditions, amazing!
3689681255?profile=original
A little demonstration (shot yesterday!) :
We modified an Iris+ drone, removed its GPS and replaced it by our board. Take-off is manual, and as soon as the drone lifted we triggered Return To Launch mode. The drone succeeded in landing on the table approximately 1 out of 2 times. It touched the table with at least two feet each time we tried the procedure.  Wind conditions were quite gentle but with a fair amount of gusts. Even if the board provides precision, there has been a lot of work on the controller’s PIDs to achieve this result!
We used a Netgear WiFi router to transmit raw data from the base to the rover, using Edison's WiFi. Base was connected in Ethernet to the router, everything powered by a 4S LiPo and a 12V power module.
3689681226?profile=original
We will offer a board to the person who comes up with the coolest name for the device !
10% off on pre-order !
http://drotek.io/1PodT25
See you soon in our website !
www.drotek.com
3689681323?profile=original
  • Dear @Drotek,
    did you study the idea behind RTK corrections or just have implemented
    RTKLib ?
    I am really surprised by your claimed accuracy of 5mm
    if Prof. Takasu claimed 5cm : 5 mm vs. 5 cm
    If you claim problems with another implementation of RTKLib
    I would prefer to know the exact name and contact of third party developer of RTKLib to let us verify your claims in peer-2-peer live talks.
    Comparison between RTK Drotek (orange) and another open-source RTK solution (yellow) :"
    What was the geolocation of your ground reference station ?
    I have studied GPS ionospheric error maps and to build real high-accuracy RTK GPS you need to do more to get HDOP PDOP received from ground station to match one calculated at the rover
    and since M8 can support up to 5 constellations and you can select constellation, it makes sense to select the same constellation on both units.
    At the same time I would like to read third party analysis of theory behind the claimed accuracy of RTK GPS.
    Maybe we need more than one ground station GPS.
    I would like to know, for comparison, which exactly point in antenna, GPS PCB is represented on your GPS plots ?
    Could you point to this point on image of your RTK GPS ?
    thanks.
    BTW
    I would like to test every RTK claimed GPS and test them all
    in parallel.
    Otherwise market gets full of $600 RTK GPS solutions vs. L1 L2 $60 GPS solutions, either claiming 5mm, 5cm or 5m high accuracy.
    darius
    manta103g@gmail.com
    HOME
    Die Einheit für Erfolg. Unsere Leistungen im Bereich Simulation, Engineering und industrielle Messtechnik werden höchsten Ansprüchen gerecht.
  • Great Project!
    @Emlid
    Maybe this helps motivate you to put some more effort into the reach project? I mean the software is still beta at best and the Pixhawk integration is nowhere. Also your "todo" list on your wiki looks pretty much the same as it was in the begining...
  • @Agribird, thank you for your words of encouragement! Hope it will help you in developing precision farming!
  • @Thorsten, LoRa modules will have two SMA connectors, one for 433 MHz, the other one for 868 MHz. We will perform range tests in a few days and will report them!
  • Hi Thorsten,
    New firmware 3.01 for M8T allows you to use Galileo data. But for the moment RTKLIB does not process this data for the moment (version 2.4.3 does, but it is still in beta, available in Tomoji Takasu's Github). I have seen reports of frequencies up to 12,5Hz in GPS/GLONASS/SBAS/GALILEO with M8T.
    I usually disable SBAS for testing because of the timing issues, never seen any problem at 10Hz then.
    tomojitakasu/RTKLIB
    Contribute to tomojitakasu/RTKLIB development by creating an account on GitHub.
  • T3
    I am also interested in LoRa? Can you provide more details on this as well? What about European regulations? I am asking because as far as I know even the normal 433 (3DR) radios are not legal (at least in Germany).
  • T3
    Hi Drotek,
    looks good!
    There seem to be some problems with the M8T and 5Hz already when SBAS is enabled.
    I am wondering about the 10Hz raw data you mention on the M8T. I thought the maximum is 5Hz. Is this a new firmware?
    Can you provide some details?
    Thanks,
    Thorsten
  • Hi drotek,
    Incredible work ! You've hidden well this project !
    We just preordered one and are already looking forward to playing with ;-)
    We are a French company that build drones for agricultural use (precision ag and spreading system). We worked with Drotek since our beginning and we can say that behind the name drotek, hides a formidable team, open source minded and with a high-level of expertise.As we often said “Nothing is impossible in drotek’s labs”. From PCB Design to electronic cards manufacture, everything is made in their workshop … and we all know that the costs in France are not the same than in China ;-)
    So thank you and continu making incredible products at an affordable price.  Big players in the drone’s open source world leaves the ship, you have to take the follow ! … and stay as you are !
    @kevin : We’re also interested in the LoRa telemetry module, keep us informed about the tests results.
  • Useful for 3G actually also if you want to get rid of range limitations. Simplest way is to use an UART radio between base and rover. But TCP allows to have a wired base connected to the Internet. Then it can be used by as many rovers as you want, in Wifi, 3G, Ethernet...
  • Yes exactly! Sorry my mistake, this is the pricing for two Edisons, there will be a small discount on the version with only one Edison.
