many of us are using EagleTree data recorder. Sometimes I have several logs that I need to merge between the autopilots and EagleTree. The manual states that you can contact them about file format and they will respond. Unfortunately this is not the case. Therefore maybe somebody has a clue about what the file content means:
TESTPLANE
0 0 0 255 1 0 0 0 255 1 254 0 0 1 0 0 0 255 0 0 0 1 100 74 1536 10.04 8205 1 1073758292
All Sessions
0 19456
Session 1
0 19456
Milliseconds IsEvent EventError EventData Altitude Airspeed ServoCurrent*100 Throttle PackVolt*100 Amps*100 GForceX*100 GForceY*100 GForceZ*100 Temp1*10 Temp2*10 Temp3*10 RPM RPM2 GPSLat GPSLon GPSAlt GPSSpeed GPSCourse GPSDist GPSUTC NumSats GPSFlags SpektrumHolds SpektrumLostFrames SpektrumAFades SpektrumBFades SpektrumLeftFades SpektrumRightFades GPSUTC-ASCII HDOP*10
0 1 9 14 0 0 0 0 1265 48 0 0 0 0 0 0 0 0 0.000000000000 0.000000000000 0.0 0.0 0.0 0.0 0.0000 0 0 0 0 0 0 0 0 04/06/2012,01:00:00.89 0
100 0 0 0 0 0 0 0 1265 48 0 0 0 0 0 0 0 0 0.000000000000 0.000000000000 0.0 0.0 0.0 0.0 0.0000 0 0 0 0 0 0 0 0 04/06/2012,01:00:00.89 0
200 0 0 0 0 0 0 0 1265 48 0 0 0 0 0 0 0 0 0.000000000000 0.000000000000 0.0 0.0 0.0 0.0 0.0000 0 0 0 0 0 0 0 0 04/06/2012,01:00:00.89 0
300 0 0 0 0 0 0 0 1265 48 0 0 0 0 0 0 0 0 0.000000000000 0.000000000000 0.0 0.0 0.0 0.0 0.0000 0 0 0 0 0 0 0 0 04/06/2012,01:00:00.89 0
400 0 0 0 0 0 0 0 1265 48 0 0 0 0 0 0 0 0 0.000000000000 0.000000000000 0.0 0.0 0.0 0.0 0.0000 0 0 0 0 0 0 0 0 04/06/2012,01:00:00.89 0
Obviously 19456 is just the number of samples, the rest are easily decoded ASCII data, but the line in BOLD contains some magic flags and options, one of them is related to time step. Any ideas?
EDIT: The field in red is milliseconds timestep size, it accepts .6 format also, and Milliseconds from the first column are ignored.
Not sure if the application can plot precisely timesteps like 333.333333 or will just truncate to 333.
Other fields remain a mystery.
BTW somebody mentioned
but it doesn't explain beyond:
Second Line: Data about your model’s setup, in an internal.
This line is needed to allow sharing of your data files with others.
Oh yes, for sure.
It also adds
Email us if you need more information on the file format.
Without promise of answering to that mail.
PLEASE POST HERE YOUR RECORDINGS *.FDR SO I CAN PICK DIFFERENCES COMING FROM DIFFERENT SOFTWARE VERSIONS - IT WILL BE EASIER TO REVERSE-ENGINEER THIS WAY.
Thanks Jani all this works. I am still working on GPS flags column... looks it is still ignoring GPS time.
What I am generating is this:
FLEXIPILOT
0 0 0 255 1 0 0 0 255 1 254 0 0 1 0 0 0 255 0 0 0 1 250.000000 74 1536 10.04 8205 1 1073766484
All Sessions
0 3887
Session 1
0 3887
0 0 0 0 0 5 0 17 1202 203 29 3 90 223 162 0 0 0 51.148418 16.996267 108.7 1.4 296 0.000 0 9 4 0 0 0 0 0 0 04/01/2012,14:17:08.00 9
250 0 0 0 -1 5 0 22 1202 214 36 5 96 223 162 0 0 0 51.148418 16.996267 108.6 1.4 295 0.000 0 9 4 0 0 0 0 0 0 04/01/2012,14:17:08.199 9
500 0 0 0 -1 6 0 28 1191 335 37 5 91 223 162 0 0 0 51.148418 16.996265 108.6 0.7 295 0.000 0 9 4 0 0 0 0 0 0 04/01/2012,14:17:08.398 9
750 0 0 0 -1 6 0 33 1177 558 33 1 92 223 162 0 0 0 51.148418 16.996265 108.6 0.7 297 0.000 0 9 4 0 0 0 0 0 0 04/01/2012,14:17:08.801 9
1000 0 0 0 0 6 0 39 1157 827 37 6 96 223 162 0 0 0 51.148418 16.996265 108.6 0.7 297 0.000 0 9 4 0 0 0 0 0 0 04/01/2012,14:17:09.00 9
1250 0 0 0 0 6 0 45 1133 1225 39 8 96 223 162 0 0 0 51.148418 16.996265 108.6 0.7 296 0.000 0 9 4 0 0 0 0 0 0 04/01/2012,14:17:09.199 9
Ah, okay. I'm not sure about those parameters. I used everything but those before.
I would like to know the meaning of every parameter marked in Bold. are those setups like units (imperial vs SI) or other stuff, since I want to not waste time comparing with data recorded with EargleTree and figurign out why certain things are not as usual.
What exactly are you trying to find? I've worked with the data some before and can help if I know what exactly is confusing you.
