Distributor
Easy Star Bathtub mod :-)
3689396993?profile=original
Here is my quick mod to make it easier to fill up my Easy Star with all the gear. The lid will be held in place with 6 pair of magnets glued to the fuselage. I did the prototype with 3 mm balsa but the next version will be in 2 mm ply. I will probably make a box on top for the APM and better pockets for the XBee and GPS.
3689397041?profile=original3689397121?profile=original3689397146?profile=original3689397168?profile=original
    It is a Turnigy Inrunner 2835 2200kv and an APC Thin Electric 6x5.5. Works really well and is very silent
  • Humm I suspected this might happen by way of crashing my stock one. They get to look like a jijsaw after awhile. Hey what motor and prop are you using? I like the look.
    Well i am planning to fly it "Granny style" (nice and slow). The EZ usually does something like this when it goes down:
    I noticed that the front was sturdier with my lid on. I am scrapping the magnets for holding the lid. i will use electrical tape and just wrap it together like in my preflight pic. I am making a new version in lightweight ply this weekend with a box or "coffin" running along the length of the lid for the APM, GPS and possibly a camera in front.
  • I really like the mods however my plane has an afinity for the ground, so much so that my daughter said it now looks like a jijsaw puzzle. She dubbed it Saw I after the movie. Anyway if yours doesn't land more or less in a level latitude I will be interested in whether the nose holds up ;-)
  • My understanding of it is, you should be right as long as the pitot tube is not affected by disturbed air flowing around the fuselage (or wing) of your plane. So keep it a little away from the plane's body wherever you put it. That's why its toward the front of the Easystar in that picture (or out a little from one of the wings on other models) - to get it out in clean air. I believe its less important for the static tube provided you don't put it somewhere like directly over the wing where the pressure is lower (provided you're flying of course :-) ).
    My pitot is not enabled yet. i saw that mounting in the APM manual here: http://code.google.com/p/ardupilot-mega/wiki/Airspeed. I guess you can mount it anywhere you like as long as it is pointing forward and is not affected by a propellerstream. Check the manual. Good luck!
  • Some questions:
    Do the pitot need to be inserted as show on the last comment image, or can they be mounted on the wood?
    Is their position important for the measures? can they be placed further back on the plane?
    No, i didn't forget my wings... :o)
    3692190214?profile=originalIt flew fine. I followed Phil's advice and moved the XBee to the wings. I also had to move the battery to the back an inch or so.
    Thanks, i will try to fly it in a few minutes. No wind this morning. :-)
