The chassis/airframe holds the majority of the parts so that is obviously the main focus of my effort. To go into the chassis I have a Hacker A30-16M motor, an eTronix 40A ESC, a 2200mAH 3S LiPO, a Futaba R617FS receiver, rudder servo and all the cables.
My first problem was the chassis being glued. If you cannot reach it you cannot fix/replace it. Neodynium magnets are mentally strong and the chassis has plenty of mounting points for glue so why not "convert" them to magnet holes. Using a drill bit of the appropriate size I purchased against the foam to leave a visible mark then with a scapel (yes a surgical scapel, exacto knife will do though) I simply cut along the line and poked out the foam in the middle. Picture below shows first few holes done and chassis cuts for battery and ESC.
I used the magnets but with my new setup its all glued up. Old way was fine but when you put 140g of lead in the front to balance it things probably aren't perfect :D
Now the setup is almost perfect with 0g of lead
Thanks,
Sam
Thanks,
Sam
The magnets are from eMagnets in the UK. I bought two sizes: 10mm dia x 5mm depth and 15mm dia x 5mm depth. They worked well installed like this for quite a while only the heavy landings mad the airframe move even in the slightest.
In the mean time I have done some more fiddling thanks to others on this forum.
The ESC being there is NOT good. The ESC needs airflow so you can stick it out the bottom or side or top (as I have now done). I have used a RAM chip cooler with some thermal adhesive on the bare metal cooler to keep temps extra low. Also my engine while being powerful needed more RPM so I've lost 200w and gained 1700kV and its much more spirited. I am also making the final preparations to epoxy the airframe together. I have shifted everything (except the telemetry) for better CoG but am checking everything fits together closed before I actually seal it up.
I'll put up a blog post showing the new layout soon.
Nice...I just got my easystar and thought about doing this. Where did you get your magnets?? What size did you use (including the ones for the wings)? Did you cut any air-flow slots for the motor controller? Thanks for all the help and insight! Ohhhh....and awesome blog :)
Sam R.
