EMC Shielding for ArduCopter3.0
The EMC shielding material reduce magnetic interference that is good to ArduCpoter3.0.
Measurement of magnetic interference becomes half by 60micron meter low-loss,high permeability nano-crystalline material.
3689532263?profile=original
Without magnetic shield
3689532249?profile=original
Magnetic shield applied
3689532347?profile=originalMagnetic shield material is Hitachi FINMET low-loss,high permeability nano-crystalline material.
http://www.hitachi-metals.co.jp/e/prod/prod02/p02_03.html
Similar material from 3M™ High Permeability Magnetic Shielding Sheet 1380 will also work.
  • I am going to give this a shot. I have some interference and vibration issues that Oliver pointed out. Hopefully it will be as simple as putting a piece of this under some moongel and putting the APM on top of that.
  • how does this compare to, say, copper tape connected to ground?
  • @Thomas,
    Thanks, but weight is really a priority:). I'm prototyping long flight duration multicopters where low weight is a key ingredient.
  • Admin
    @Ken,
    If you are not concerned about weight, buy the 3M sheet and do not take the backing off the adhesive side.
    TCIII
  • Where can I buy the thin film without adhesive:)?
  • The weight of the film (95mm x 55mm) is about 1.5 gram without adhesive.
  • Admin
    The 3M material can be purchased as thin sheets on eBay: http://www.ebay.com/itm/160613440162?ssPageName=STRK:MEWAX:IT&_...
    TCIII
