  • What would be the best way to do energy harvesting for a fixed wing MAV ? (500 grams or less)
  • George,
    The thermal harvesting idea is one my university has been trying to figure out. We found these papers by a researcher early this year: (In no particular citation format)
    Allen, Michael J.; Updraft Model for Development of Autonomous Soaring Uninhabited Air Vehicles; NASA Dryden Flight Research Center, Edwards, California 93523-0273, USA; AIAA
    Allen, Michael J.; Autonomous Soaring for Improved Endurance of a Small Uninhabited Air Vehicle; NASA Dryden Flight Research Center, Edwards, California, 93523-0273, U.S.A.; AIAA
    Google Scholar should have to problem getting these for you. Basically, This guy has the model for the average thermal field, and has written the matlab code for getting into these.
    As to the barometric pressure sensor, I'm not sure. I've heard of ideas of using thermometers to sense thermals, but the response time was in question. One thing I know doesn't work is trying to see them, as thermals get blown around anyway, and so are not always exactly over a hot parking lot. (And most thermal cameras will break the bank.)
    -Steve
  • It is both good and bad news for me!
    Good, because it means I was not so crazy after all, I was thinking about the application of magnetic field around HVLs for powering/charging a small UAV a few months ago specially after seeing this http://www.scienceprog.com/the-bright-field-with-thousands-of-fluor...
    Bad news because I did not do anything about it but some research and now it has been patented. Although the patent has been filed in 2005 long before I had come up with the same idea :)
  • You can read the full patent application here:
    http://www.freepatentsonline.com/7398946.html?query=us+7%2C398%2C946
    The patented idea is the procedure and the respected mechanism as a whole, not the idea of recharging uavs from powerlines in general.
    Power line sentry charging
    A rechargeable battery energized unmanned aerial vehicle having surveillance capability and an ability to clandestinely collect propulsion and other…
  • Why this one can be patent?
