Following on my Carbon H-Quad, I have now built a foam one!! (Ok, it has a bit of carbon too)
The problem with the full carbon one was weight. Yes, it was super stiff but it was around 300g heavier than my X525 frame and thus my flight times were 3+ minutes shorter, thinner carbon plate would've helped but it's fairly expensive, difficult to come by (here) and difficult to work with.
My main priority was portability, it has to fold as small as possible and I also really do prefer flying the H-frames, orientation being the major advantage but also no props in onboard video.
I had a few blocks of a hard black EPP foam and I picked one up the other day and it was really firm (no twist) AND light (100g for the whole block), suddenly... bing!... I had spare arms for the X525 so why not.
A quick drawing in CAD to check the angles and sizes and some problem-solving with mountings and construction and here it is... took about 2 hrs to make and another 2-3 to assemble. I used the carbon pivot plates cut off from the old frame and they're just cyanoed to the foam with 2 bolts right through and 2 through just the arms and plates. Flies really well with very little twist (not enough to cause the yaw problems associated with twist)!
Weight is 925g ex-battery so 78g lighter than the X525 with the same components (The carbon frame was ~1300g).
Diagonal (open): Motor to motor (open): Length (folded, max): Width (folded, max): Weight:
EPP-HFQ 690mm 490mm 435mm 160mm 925g
X525 550mm 400mm 795mm 160mm
1003g
Before attaching the motors, closed Open, no components
3 4
5 In the old box!
Comment by Louis on April 12, 2013 at 7:16am
Very very nice !!
Comment by Louis on April 12, 2013 at 7:18am
Will we see it fly tomorrow ?
Comment by Graham Dyer on April 12, 2013 at 7:21am
Now you believe me, Louis...
Comment by Louis on April 12, 2013 at 7:41am
Not yet, will if i see it fly tomorrow !!
Comment by John on April 12, 2013 at 7:59am
I think it will fly but the question is... will it float??
Comment by Graham Dyer on April 12, 2013 at 8:03am
Well, it has flown so no worries there, floating, yes well... probably, need to waterproof the APM first, me thinks...
Comment by Tom Mahood on April 12, 2013 at 8:59am
I am curious why you used mounting plates beneath your front motors but not the rear ones?
Comment by Graham Dyer on April 12, 2013 at 9:02am
@Tom - to make the motors equi-distant apart when in open position, the front arms' angle is more acute so the motors end up being closer together.
Comment by Graham Dyer on April 12, 2013 at 9:24am
Comment by The Sun on April 12, 2013 at 9:29am
Simply too awesome, I love the design.
Comment
