Fiberglass MQ-9 Reaper with 2.5m wingspan
This model is big! 2500mm is impressive by any standard, yet the model is very practical, for instance the highly efficient balsa wing is removable for transportation. This model is highly unusual being both a scale model and a purpose built FPV/Camera platform. The Reaper UAV is a development of the Predator and represents the latest in cutting edge military technology, it is also much more than a mere surveillance aircraft, with its armament of Hellfire missiles and laser guided "smart" bombs, it is a hunter/killer with an impressive combat history.
Specifications:
Wingspan: 2500mm
Length: 1080mm
Wing Area: 32.5dm2
Wing Loading: 76-83g dm2
Airfoil: Eppler 374 Mod
Weight: 2500g~2700g
This MQ-9 comes as ARF, the following is required to complete this plane:
5~6 Channel TX/RX
36~42 Outrunner or Inrunner Brushless Motor
40A~60A ESC
2 x Standard Servo and 4 x High Torque Micro Servo
3500mAh~4000mAh 3s or 4s Lipoly Battery
For FPV use, this model obviously ticks the boxes, its difficult to argue with the design of the Reaper! There is plenty of room for FPV/Camera equipment, the scale under-slung camera pod is supplied in such a way that it can be fixed or made rotating with a little effort and comes with glazing. For FPV use obviously the model weight will increase and you may want to consider a 4s set up, prop range is 11"-12". However you fly it, this is an impressive model in every respect and is bound to be a talking point wherever it is flown.
Available from Hobbyking for US$ 100.36, see the product page for details. If you stay on the site for a while, a one-time offer window appears to budy this plane for US$ 94.96. Price may depend on your membership level at the shop.
    I have elected to UAS a large HK 2350 mm Piper Cub L-4 Grasshopper @ $220 I also have a medium size 1850 mm version @ $104 both can carry all my gear, but 2350 has plenty of payload still available, maybe a WiFi sniffer or small SAR.  I also have a Ventus 2hx, but with it's high wing loading, it will be a bear to fly. I added flaps and extended wing cord 3/4" at trailing edge of whole wing, but have not flown it yet.
    Keep your speed up and RQ-9 will fly great, watch out for tip stalls when turning.
  • Has anyone put a gas (2-stroke) engine on this?  Does anyone have any information on what poly gas tanks fit this thing, and how much flight time they can get out of it (gas-powered, not electric)?  Thanks!
  • Indeed Marco it would seem that scale UAVs are just bad but as of yet we have only seen predators, reapers and globalhawks. I can't wait for the sea avenger, X45B or some other ones finally arrive. Swept wings and flying bodies should help the scale thing
    Yes, this came out a year ago from Nitroplanes. We've had a bunch of reviews and buildlogs here already. I've got two of these models, but I only use them for display (never flown). Here is my comparison post on the big and little ones that Nitroplanes sells.
    http://www.diydrones.com/profiles/blogs/comparing-the-little-and-the
  • This has been out ages and has a wing loading 0.18Oz/in² which pretty much rules out this as a trainer craft (for beginners). It looks great but according to the RCGroups threads flies rather more sedate than expected because agressive moves unsettle it (not that hasn't been seen so far in all the UAV models though just search for PapaJeff).
    As model the looks are great and the P&T camera dome at the front could be good. Shame its 30Oz too heavy really.
  • Is this the projet mq9? It looks exactly like it. I heared it doesn't fly well
  • Nice!!!!
