I knew I would need a charger so I picked one up from a LHS (My previous blog post has that adventure).
So what else did I need to pick up?
- Servo extension cables (The stock servo leads are just long enough to get inside)
- Battery connection adapters or new leads to solder on
- Epoxy since there wasn't enough that came with it.
- Power transformer for battery charger (You might not have to pay for that if you get a different charger)
- A five wire balance plug to a four wire plug.
Tools that I have used
- Hot wire foam cutter. I made mine out of chopsticks, a clothespin, 9V battery, a rubberband, and some florist wire. One of the ailerons stuck during movement against the body.
- Digital Multimeter To check my solders on the connectors.
- Soldering iron and solder
- Pliers
Some elaboration:
My SkyFun came with a Deans connector (the unsoldered part) while my batteries came with a XT60 adapters. My biggest problem seems to be what plug to go with (I like soldering) a compulsive person would get a scale and weigh them. I am going to be lazy and bet on the XT60 gaining a majority so it's time to cut the plug off my SkyFun and get to soldering.
I ended up picking up a CellPro from FMA Direct since HK was out of stock for the US warehouse and I was impatient and I didn't want to spend another $20+ on just S&H. I did buy batteries from HK though since they had them in stock from the US warehouse. The charger however did not come with an AC adapter so I either have to charge from my cars battery or get a power transformer. The other caveat is that my charger is a four cell charger while I only have three cells. What this means is that I have a five wire plug that needs to go to a four wire. Luckily the manual describes the wiring schematic so you can buy your plugs and crimp your own adapter wires.
Ahhh I thought I hit the draft button on this I hadn't proof read it and I have more to add. This is my second electric plane but since the first was a kit skyfly that a gf bought me it doesn't count. My first plane was a high wing trainer that had enough gas for 45min and finicky exhaust when I was 12-13.
Besides SkyFuns are easy to replace when I do crash it.
