Finwing Air Titan
ai16481373-114-thumb-AirTitan-02.jpg?d=1391621339Looks like a good fpv/camera ship for long distance flights with ArduPlane.
$189 - airframe kit only
http://www.readymaderc.com/store/index.php?main_page=product_info&cPath=101&products_id=2482
http://youtu.be/9stpfujoUcA
Specifications:
  • Wingspan: 2520mm / 99.2inch
  • Kits Airplane weight: 2.4kg (5.3lb) including all reinforcement parts
  • Extra Payload: 3.0kg-4.0kg (6.6lb-8.8lb)/ flight weight>6.0kg
  • Customized Brushless Power system:
  • Customized Motor for Airtitan:  M60K/ Power 1500W
  • Testing static thrust: 5.5-6.0kg (6S, 15" Prop)
  • Propeller recommend: 15*6 / 15*7
  • ESC: Advanced 80A OPTO (without Built-in BEC)
  • External UBEC: 5V/6A,5.5V/6A or 6V/6A (Switchable)
  • Material of fuselage and Wing: EPO
  •  Bought  one today guys , the kit version. all  the ready to fly where gone, I liked the skyhunter but i would have to buy /build a landing gear also the Talon. this bird has it and its steerable .should be here by next Wednesday :))) salivating already . good night to all
  • Sorry Jarrett.. Didn't see this until just now.  Yes I got it and it flies quite well.  I have it apart right now for some changes (mostly related to FPV and Pixhawk placement) but hope to get it back in the air Monday or Tuesday and get it tuned.
  • Deal.  Ordered.
  • It's taking so much self-control not to order one of these and drop an APM in it!  Looks to be a good ship for several applications
  • Ailerons do not appear to be direct-drive: http://www.readymaderc.com/store/images/AirTitan-01.jpg
  • However notice
    • The sturdy undercarriage avoiding hand launching a buzz saw like the X8
    • Steerable nosewheel so you you don't fish tail all the way down the runway
    • Plenty of wing area for load carrying.
    • Upper deck to put comms gear on well away from the autopilot.
    There are some advantages to this aircraft.
    My 0.22 cents worth:
    - Looks like no flaps, only ailerons and ailerons don't go to the wingtips
    - enormous black aileron hinges
    - twin vertical fins seems unnecessary and they're slightly out of the propwash (but they are big)
    - added weight of extra fin, rudder, servo and hardware.
    - empty weight seems a bit heavy
    - 1500W, for what!? To test flutter? Go into orbit?
  • Is that flush servo's I see in the wings? If so, I'm surprised we don't see more direct-drive servo use. I understand there are packaging reasons to use linkages, but even still - would like to see more direct drive use - less bits to go wrong, and more aerodynamically efficient.
  • too many tails!
    Its going to be upto the first 50 folks that buy it to get the truth out.On paper it looks cool. (and in that shot)
