Fixing Nightvision Problem on Cheap Pinhole Camera
3689558231?profile=original
Greetings all.
This is my first blog post on DIYDrones, I’ve been a member for a little while now and have asked a few questions of the members as the need for info or help on a particular problem has arrived.
First some background info on my project:
I have a Big love for fishing, Specimen Carp Angling to be more precise, but I’m a lazy fisherman… Now to use a RC Boat to take the bait out into the lake is nothing new, but to automate the process… Well let’s just say when I stumbled on the APM Project I knew what my next project would be: DIY Bait Boat with an Autopilot.
I am still busy putting all the parts together and will post a blog or discussion once the project is completed.
In the meantime I would like to share a problem I picked up with the camera I purchased and my solution to it.
The camera is very cheap, around $10. It’s a Covert Pinhole Camera with a 3.6mm lens, 520TVL (PAL), good image quality, problem is when I tested it in the dark last night you can’t see anything but darkness. I don’t know how many of you would be operating your quads, planes, rovers and maybe boats at night, but I will be doing so quite often. I could go and buy another camera (at twice the cost) with Infrared LEDS, but that means more weight different mounting etc. Besides there is no fun in that!
So I decided to build a LED Array to provide light to the video image. I designed two simple printed circuit boards, one capable of accepting 12 5mm LEDS the other 12 5mm LEDS and 12 10mm LEDS. I can use super bright white LEDS or Infrared. Simply calculate the correct resistor value needed according to the supply voltage and your set. Both boards are single sided and relatively small, the small one has a diameter of 62.5mm and the large one a diameter of 95mm. There is a cutout in the centre of both boards for the camera lens with a diameter of 33mm. Cost for 6 Prototype PCB’s of each plus LEDS and resistors is around $10.
I’m attaching a few pictures (Renderings) of the boards. If anyone is interested or has a need for this I will post the Gerber and NC files at a later date.
70906016?profile=original
3689558402?profile=original
3689558363?profile=original
3689558337?profile=original
3689558415?profile=original
  • If only we could use those fancy new MP IP cameras... Then again too expensive. Id also like to experiment with a ptz camera for fpv, but that would require coding skils, of which I have none.
  • Currently I have a 520tvl (hobbyking), but I'd like to get the "690TVL DPS HD Ultra WDR Pixim Camera"
    I record with the GoPro3 Black on a brushless gimbal, so I can't use it for my FPV camera.
  • I stil want to conduct a few tests to see what the maximum resolution can be with the osd. The other camera I have is 700tvl and the pinhole is 520tvl. If possible I'd like to use at least 600tvl. do you use the same camera for recording? I'd like to get a gopro, but at $300 with no extras I dont think its worth it for my aplication.
  • In regards to the pin hole camera, I was just hoping for a way to improve the FPV camera at low cost. After research I've concluded that I simply need those fancy $50-90 cameras. One day =D
    That's counter-intuitive that higher res is bad for the OSD. Since the OSD rides the composite signal.
  • Hi Daniel,
    I selected the pinhole camera for it's low cost and small size. I also have a larger IR Pipe camera, can't use it because the resolution is to high so it cancels out the overlay from the osd, you only get the video image. The pinhole camera is sufficient for most needs in my opinion, if I can get one with a varivocal lens I'll be a very happy man, but for now the 3.6mm lens is all I need.
  • Cool idea, thanks for sharing the plans. I have a question regarding the pinhole camera. Are there any benefits to using the pinhole camera? Even in daylight?
  • Pretty nice :).
    I'm just using 2x5W IR LED with driver modules and lenses. A bit more expensive ($18 alltogether from ebay) but range is about 50 meters.
