I just released new Open Source software for CompuFly USBtoPPM Interface,
This Software supporting all flight joysticks like Saitek ST290,
Software includes:
- 7 channel control by joystick
- Camera Pan/Tilt with HAD stricks and auto centering with one button press
- Rudder control from joystick
- Trottle control from joystick
- Landing gear or any remote switch On/Off with buttonsixes
- Trim/Reverse and EPA mixes from software
- 1024 step servo position for each channels
- Positive and Negative PPM selection
- Channel output selection 1 to 10 channels
- Futaba Square/Round, Hitec Round, ESky, 3.5mm Jack type Plugs Available
Software under GNU license, all developers welcome.
Product Link: http://www.flytron.com/56-compufly-u...converter.html
Download link: http://www.flytron.com/pdf/CompuFly.zip
USB Driver Link: http://www.flytron.com/pdf/CP210x_VC...K3_Vista_7.zip
Thanks for reading
Melih Karakelle
Yes, Compufly's cable includes Ground and PPM signal wires, you can modify it for all transmitters input.
And you can put it directly the RF modules too, this is very funny option for making ground station without rc transmitter, just connect PPM signal and power pins of RF Module (ASSAN, CORONA, HITEC, SPECTRUM or FUTABA RF MODULES etc)
@Hooks:
Yes it works, just configure the device for your PPM channels count and Positive/Negative Shift from software.
Hitec Round
3.5mm Jack Plug(JR and some Hitecs)
ESky round (mini din 4)
