I'm sorry to report that FMA is no longer carrying Z sensors. They ran out of existing stock and because their basic Co-Pilot doesn't require them, they won't be making any more. They will continue to make XY sensors, which the Co-Pilot does use, and those should be back in stock in a few days.
We're currently exploring alternative sources for the Z sensors, but in the meantime, I suggest you buy them from Dean Goedde for $40 including cable (scroll to bottom for price list).[Update: Turns out that those may not be totally compatible (they're 3.3v and require special wiring to our 3.3v shield). Stay tuned....we're looking at other options.]
[Update 2: Dean writes and says that they are compatible: "My Z head is 100% fine at 5V. The analog output will be 1/2Vdd for a balanced horizon view, and skew away based on tilt. After all, myself, FMA, and Paparazzi are all using the same components and design. The AD8551 OpAmp is being used in all 3 of our Z heads and is fine to at least 5 volts.]
Only one suggestion. i just discover that you need to have XY and Z with the same gains in order to work correctly. Otherwise the range scaling will be unbalanced... Paparazzi THemopiles will work but the gain is 1100 and the original FMA gains are set to 1960. In other words the paparazzi IR have less resolution, approximately 40% less resolution (because was intended for 3.3v), and yes have the same components but the Opamp uses different resistors (510 ohms instead 1k and 1M ohm instead 820k). But will work if you buy the xy and z modules! But please do not mix FMA with paparazzi.
In the other hand i just made another IR boards, using the FMA connectors and with the same gains (1960). But i will sell only the board (without the thermophiles), i will provide the sensor separately but you will need to solder them manually (easy).
@David Conger
Wow, my respects about making all the cables manually (never mind).
Today suppose to arrive the nice cables for ArduPilot, so only minor soldering is required (easy).
i think you should cancel your z axis order and I will call them up shortly after ;-)
so I assume this means we don't get to program our waypoints with the nice GIU interface that the 2.1 and above guys do? I have still to hook everything up but I am curious if the interface is different with each version.
On enquiry to FMA I received an email back today saying that they will ship my Z sensor and the XY sensor when the XY stock arrives. They predict later this week, lets live in faith :)
http://www.rcgroups.com/forums/showthread.php?t=732783&highligh...
Yes you can do that... We only need the extreme difference of temperature, to fit the scale.
thanks all!
1
2
3
4
of 4 Next
