http://www.eodevices.com/main_erc_2kit_frameset.htm
Electro-Optical devices sells kits and spare parts to build a real, far-ranged LIDAR ranger, such as: nanosecond timer, transmitter module (high voltage laser power supply included on-board), receiver module (APD photodiode, PIN photodiode), controller, laser diodes (power 10W - 75W).
The price of the cheapest kit ERC2-KIT is $ 429 , but you can get even cheaper if you buy just the modules and assemble it yourself.
The boards are really small and are thus ideally suited to fit an UAV plane which includes a rotating mirror system and a capable memory onboard.
Maybe there are some restricting laws about the power of the laser? Anyone knows?
Hey Mike, you are correct. But we could even trust the data coming from a barometer or better, an array of barometers averaged together. i think mapping would still be possible and a new source of pure fun from UAVs
below is a viable configuration for mapping purpose:
And the mirror mechanism (which should be DIY made)
Chris for terrain mapping you still need an accurate altitude of the aircraft relative to the datum. Obvious way to do this is with RTK. I have been testing this with small antennas but they really don't cut it and the one that I have had some success with are very hefty indeed in modelling terms. Also consider that a simple LIDAR system with only measure at points along the flight line - so if you want a high density DEM then you will need to fly an awful lot of closely spaced lines.So for me the best terrain mapping option remains digital photogrammetry which just requires some ground control at which level the RTK antenna weight is not an issue.
Mike
As I read the datasheets, it appears that you can get the complete ranging system by getting just the ECH-1B which is a chronometer measuring time between a start signal (generated, 5V compatible with TX module) and an input signal (received from photodiode), the ETX-10A (which has HV laser driver) and the RX-5XF. This should be the cheapest option; communication is done via TTL compatible protocol, so it should be Arduino-friendly. Oh and please note that the mininum range stated is about 50m, even if the ECH-1B datasheet suggests that it can go even lower. So no Hokuyo-like...
Repetition rate up to 250 Hz
How strange, i've contacted them a month ago but still no reply...
