After much chasing, and testing, I have found this to be an efficient way of getting low latency high quality HD video out of an Aircraft. The latency is around 0.4 seconds at worst which would be OK for an FPV with an APM doing the hard work.
I will continue to search for methods to drop the latency down further, but this is a lot better than the 6-12 seconds I was getting on my first attempts.
Any comment (with useful instructions) would be appreciated.
For the wireless link, I am using two UBIQUITY ROCKET M 900 with Australian ACMA approved firmware, at the base station, I am using a tracking (yet to built the tracker...) 1.5 meter long X and Y polarised Yagi, and on the plane, two RF Design flexible strip antennas, placed at right angles to each other.
but how you do that bit is up to you.....
the critical bit is getting the Raspberry Pi's to chat to each other.
I have tried to make this as user friendly as possible... good luck.
Setting up IP video for Raspberry Pi 1080p video (FPV)
You will need 2 B model Raspberry Pi's and 1 Pi Camera. (Element 14, or RS components)
Preparing your Raspberry Pi for first boot…
Follow the instructions at http://www.raspberrypi.org/wp-content/uploads/2012/04/quick-start-guide-v2_1.pdf
Install the prepared SD card in the Pi and boot.
Setting up your Pi
Connect the Pi to your router with a network cable.
On Start-up it will resize the FAT partition and present you with a menu.
Set your language, and keyboard layout.
Select Raspbian… then click install.
After this has extracted (will take a while….) it will reboot into the configuration screen (again will take a while for this first boot.)
The important things to change here are
- Enable the camera
- In advance options…..
- Set the host name (camera, for the camera end, receiver, for the viewing end)
- Memory split, set the memory for the GPU to 256
- Enable SSH ( will come in handy later, as you may need to talk to the Pi in the air.....
Then finish and reboot.
First login
Username: pi
Password: raspberry
Setting up the required programs for video streaming
Install the dependencies by running the following in a terminal:
sudo apt-get install mplayer netcat
cd /opt/vc/src/hello_pi
make –C libs/ilclient
make –C libs/vgfont
cd /opt/vc/src/hello_pi/hello_video
make
cd ~
Now repeat this for the other Pi….
Streaming…
First set up the receiver….
Ensure the receiver is connected to your network and run
ifconfig
after you press enter, you can find your ip Address. Note this down.
Then run the following.
mkfifo buffer
nc -p 5001 -l > buffer | /opt/vc/src/hello_pi/hello_video/hello_video.bin buffer
the Pi will now wait for the feed.
On the Camera Pi
Ensure camera is connected to the Pi
Ensure Pi is connected to the network (you can confirm this with ifconfig)
(see instructions at http://www.raspberrypi.org/camera for how to connect the camera)
In the following command, replace the ip address with the one you just noted down.
raspivid -t 0 -fps 15 -o - | nc 192.168.1.85 5001
if all goes well you should be streaming 1080P video at 15fps with less than 0.5seconds of delay..
now add your wireless bridge between the two, and away you go J
This information has come from the Raspberry Pi foundation website, and other sources, tested and proven by myself..
Guys,
I have been trying to stream HD video using DM368 for the last few days, and got it working over wireless today. My setup was: GoPro Hero (HD component out) -> analog-to-digital converter -> TI DM368 (conversion to H.264 and send using TCP/IP) -> wifi-> wifi-> Macbook Pro. End-to-end to delay was less than 500ms (including the delay in GoPro livefeed)
However, so far i got it to work using tcp/ip, which obviously has its problems. I have been trying to use RTCP/UDP, but couldn't get the gstreamer pipelines configured correctly. Has anyone had any luck with that?
Also, did anyone find a good (and convenient) way of measuring the end-to-end latency? (or intermediate even)
Saad
The H.264 / hd fpv has been discussed previsously here as well http://diydrones.com/profiles/blog/show?id=705844%3ABlogPost%3A1246466
Good point, Justin. Maybe some frame tweaking can make this better.
http://pastie.org/pastes/6638573
It is a function of how H.264 works, nothing to do with the raspi. If the sotware is set up to have a constant frame rate (as opposed to constant bit rate) you should be able to see a change in your data rate on your computer when things start to move in the image as you stream the data.
If you research the basics of video compression/h.264 you can get more details, I could not quickly find a document that explains it simply.
Hi @Justin,
I did not know that. Can you tell me if you found the RPi camera datasheet and/ or tell me the source of that information (about static image/ compression)?
Yes, the 920 has H.264. I still use the hw encoder in the Rpi to encode to the right resolution and datarate. I got 300ms latency, more or less.
@Philip,
sure that was my question ... but i see that 920 stream directly in h.264 by gstreamer so you don't have latency to compress the frame ... the raspberry pi is only a router of packet ... and front end interface :)
If you use pi cam instead the RPI use RPI hardware encoder .. the result is the same about latency but the approach is totally different :) I doing a lot of test with neuron about this kind of approach neuron don't have inside an h.264 encoder i used archlinux as os in my test ... RPI use Debian instead ... right ?
Best
Roberto
To those that are doing bench testing, make sure to point the camera at something that causes most of the image to be constantly changing. The compression works by only sending areas of the image that have changed, so a totally static image becomes very fast to transmit, whereas the whole image is much slower. There is another discussion about this very fact somewhere here on diydrones. I saw point it at something constantly moving because when you fly fpv essentially your whole image will always be changing as you fly around.
12
13
14
15
16
of 21 Next
