After much chasing, and testing, I have found this to be an efficient way of getting low latency high quality HD video out of an Aircraft. The latency is around 0.4 seconds at worst which would be OK for an FPV with an APM doing the hard work.
I will continue to search for methods to drop the latency down further, but this is a lot better than the 6-12 seconds I was getting on my first attempts.
Any comment (with useful instructions) would be appreciated.
For the wireless link, I am using two UBIQUITY ROCKET M 900 with Australian ACMA approved firmware, at the base station, I am using a tracking (yet to built the tracker...) 1.5 meter long X and Y polarised Yagi, and on the plane, two RF Design flexible strip antennas, placed at right angles to each other.
but how you do that bit is up to you.....
the critical bit is getting the Raspberry Pi's to chat to each other.
I have tried to make this as user friendly as possible... good luck.
Setting up IP video for Raspberry Pi 1080p video (FPV)
You will need 2 B model Raspberry Pi's and 1 Pi Camera. (Element 14, or RS components)
Preparing your Raspberry Pi for first boot…
Follow the instructions at http://www.raspberrypi.org/wp-content/uploads/2012/04/quick-start-guide-v2_1.pdf
Install the prepared SD card in the Pi and boot.
Setting up your Pi
Connect the Pi to your router with a network cable.
On Start-up it will resize the FAT partition and present you with a menu.
Set your language, and keyboard layout.
Select Raspbian… then click install.
After this has extracted (will take a while….) it will reboot into the configuration screen (again will take a while for this first boot.)
The important things to change here are
- Enable the camera
- In advance options…..
- Set the host name (camera, for the camera end, receiver, for the viewing end)
- Memory split, set the memory for the GPU to 256
- Enable SSH ( will come in handy later, as you may need to talk to the Pi in the air.....
Then finish and reboot.
First login
Username: pi
Password: raspberry
Setting up the required programs for video streaming
Install the dependencies by running the following in a terminal:
sudo apt-get install mplayer netcat
cd /opt/vc/src/hello_pi
make –C libs/ilclient
make –C libs/vgfont
cd /opt/vc/src/hello_pi/hello_video
make
cd ~
Now repeat this for the other Pi….
Streaming…
First set up the receiver….
Ensure the receiver is connected to your network and run
ifconfig
after you press enter, you can find your ip Address. Note this down.
Then run the following.
mkfifo buffer
nc -p 5001 -l > buffer | /opt/vc/src/hello_pi/hello_video/hello_video.bin buffer
the Pi will now wait for the feed.
On the Camera Pi
Ensure camera is connected to the Pi
Ensure Pi is connected to the network (you can confirm this with ifconfig)
(see instructions at http://www.raspberrypi.org/camera for how to connect the camera)
In the following command, replace the ip address with the one you just noted down.
raspivid -t 0 -fps 15 -o - | nc 192.168.1.85 5001
if all goes well you should be streaming 1080P video at 15fps with less than 0.5seconds of delay..
now add your wireless bridge between the two, and away you go J
This information has come from the Raspberry Pi foundation website, and other sources, tested and proven by myself..
I use the AWUS036NHR V2 2000mW model....
Why the AWUS036NH instead of the AWUS036H? Most of the reviews Ive say the H model has better range than the NH model.
Tommy Larsen, this is just funny for anyone who work with RF :) "Power king" meter from Youtube is funny too.
Even if you don't understand anything in RF technology, you can disassemble your "99W Wi-Fi adapter" and check out datasheet for output amplifier IC.
2W output from cheap plastic adapter powered by USB - its fantastic for "backtrack DIY WiFi hacking" kids, but for our real tasks (such as HD FPV) its totally useless.
If you don't believe me, you always can try! This adapter have 2W of output power and fantastic sensitivity (-92 dBm) in 802.11b mode (it's enough for 5 mbit/s FullHD). So you can use short whip antennas (2 dB) on ground and same on your RC model and get 25 km of range! And with small 12 dBi antenna on ground, you will get about 80 km LOS range. What a great solution!
Ok, i think you got a fake adapter.
https://www.youtube.com/watch?v=lm-147XPpSM
There is no alfa adapters with more than 0.2W of output power ;) Just measured all of them (original from taiwan)
Rocket M5 says also 0.5kg in the datasheet... I'm working on a solution with Alfa 2000mw adapters and Cloverleaf or similar.
Real possible delay is 0.1 - 0.2 sec. 0.5-1-2 sec delay is from wrong tuned software (useless cache etc)
Here is my FPV setup https://www.youtube.com/watch?v=5-zg8jXhChM
With simple USB-WiFi adapter (100 mW) you can go FPV up to 500m with 12 dBi antenna and more with bigger antenna. And such adapter weight is 5g without case. It can be good in small-quad setup for low-range FPV
I just started working on my own Raspberry Pi video streamer. It seems like you went away from gstreamer to netcat-mplayer, is that because there is no gstreamer support for Windows?
With my first attempt I ran on Windows:
And on the Pi:
And I get video but its got really bad lag, 6 seconds at least. This is over my home wifi network. How did you reduce the lag and how do you specify UDP over TCP?
This is very interesting, I read through the whole thread and Id like to buld something similar. Im wondering about the reasons for usoing a NUC on the ground station vs a second Rasberry Pi? Also, is there a technical reason why you dont run telemetry over the same link as the video?
7
8
9
10
11
of 21 Next
