Wing Span: 1.6m
Length: 1.1m (nose to tip of v-tail)
Max Weight: 6kg
Recommend 4 Channels (Aileron, V-tail, Throttle)
Power: .45 - .65 cu.in. or equilvalent electric power
DOWNLOAD ZIP FILE HERE!!!!
hxxp://www.hawkeyecs.com/tmp/rvosuav.zip
copy and paste url and replace xx with tt. that is the file I just downloaded and opened. I use winrar to extract the zip file.
@ AA Funi I just downloaded the zip again and it extracted fine, I also opened the assembly in Solidworks. I would try downloading it again possible something went bad in your download.
I'm fairly new to RC and am headed for FPV. I went with an Easy Star and it's fine. If I could go back I'd get the Sky Surfer http://www.bananahobby.com/1937.html
It has the same specs as an Easy Star but comes with ailerons (very helpful if you want to make a UAV) and radio. All for $100. I'd probably go with the brushless motor upgrade. Just my $0.02.
You could try either of these links for your easybee.
http://www.rfsolutions.co.uk/acatalog/EasyBee_Zigbee_Module.html
http://www.abacom-tech.com//ZigBee-RF-Transceiver-Module-EasyBee-P9...
It is by no means an exhaustive list.
Google is your friend.
