Lesson learned: don't try to wire small circuitry at 11pm at night. Last night I received a small CMOS video camera + transmitter combo (2.4 ghz LTS wireless camera) and put it on my E-Flight Blade MSR. I was actually able to lift this + battery, although it was certainly struggling. However before I could record any video, I managed to cross the positive and negative wires on the battery, and I fried a capacitor and possibly a majority of the circuitry on the 2.4ghz camera transmitter board.
So, results are in: Yes my Blade MSR can lift this rather large camera + battery, and no, the camera does not like it when you feed positive 9volts into the transmitter ground. I'm going to see if I can get a replacement surface mounter capacitor, but frankly, I think this may not be fixable :-(. Either way I'm no longer going to wire circuitry at night when I'm tired.
On a better note, check out these cool pictures from the board!
Above: identical capacitor (that IS a capacitor, right?) to the one I fried. I need to ID this...
Above: Camera on left (backside of CMOS board, and crispy 2.4ghz tx on right)
Above: CMOS
Above: CMOS zoomed in. glass is not very clean.....
Above: CMOS, focal point is on circuitry under the glass
Above: even closer
http://www.engineersedge.com/instrumentation/tantalum_capacitors.htm
Also they are marked backwards from regular capacitors so make sure you pay attention when mounting or else.... pop again. They can be really finicky too...
I'll was using a nikon NEXIV vision system to take the pics. I'm glad you like the pics, I thought they were very cool too!
Take the time to do it right. Sorry for being so harsh. You will probably not let this happen again, but I'am thinking of others who might read this.
