FrSky Taranis Setup 6 Flight Modes plus 1 for APM Ardupilot
Using a FrSKY Taranis X9D, we have been mixing different switches and testing 7 flight modes. RTL on a one-switch return home and 6 other flight modes.   We have included our video logs of how we set it up.   You can use any switches following our3689554728?profile=original example. Since there are so many 3 position switches on a Taranis, you can spare one for a mix.
With 6 CS switches, you can next easily assign sound files to each flight mode.  We will also include the sound files (voice) of all the flight modes in the next video and a link to download them.  Maybe someone will find these useful.  Cheers!
3689554793?profile=original
Previously Part 1 of 3: FrSky Taranis and Setting Up Basic Switches
3689554908?profile=original
Next Part 3 of 3: Adding sounds to flight modes
3689554921?profile=original
  • 100KM
    Thanks noeL I've done this and it works, however when SG is position 3 (down), I'm in mode 6, which is manual, which can not be changed. I can't figure out how to engage mode 6 when SG is in position 1 (up). I'd like to start in manual mode, with all the switches up. I've tried simply chancing CS1 and CS3 but when I use SD some modes are not reachable.
    Any assistance appreciated.
  • Isaac
    Thanks for the feedback.  I was going to suggest remove the delays and see what happens.  You should be okay removing the delays.
  • Brit: Thanks for help to clearly explain the issue.
    noeL and Brit: I try to eliminate the 0.5s delay in the "custom switch" page and it seems solve this issue in my Taranis. So is there any special reason to put the 0.5s delay? Because I usually assign flight mode 6 as RTL and for sure I don't want the copter go into RTL when I switching mode. Thanks everyone help me to look into this issue.
  • Sgt Ric, yes, it is still an issue :(
  • Hi Isaac
    sorry, which video are you referring to?  On Ep 28 video, it seem to just go to the first flight mode, where your first position switch is set to.   If I recall right, Taranis will not allow you to proceed until all your switches are on first position, but you can overwrite the warning message.
    We don't have a Taranis to check right now, until the next one arrives, as that one was shipped away after the build.
  • Hi noeL, How come the flight mode will always first switch to the flight mode 6 before switch to the correct flight mode as shown in the video?
    Is this still an issue?
    quote "...I can't use P3 in Custom Switches or Custom Functions" posted by  Alexsey Novik on November 13, 2013.   (setting up a 6 position switch on a Taranis)
  • Any ideas how to use mode sounds with 6pos switch, like this one?
    http://diydrones.com/profiles/blogs/6-position-mode-switch-for-apm?...
    It is Pitch Trim Pot (P3), replaced by simple rotary 6 position switch.
    I realized that i can't use P3 in Custom Switches or Custom Functions.
  • Yes, once you have your Switches setup, you can fire different rules and assign sound files easily.
    In Part 1 video episode 25, we demo three modes just using Custom Function (CF) for the three switch positions, if that is all you need. In Part 2, Custom Switches (CS) Mix. In Part 3, of the video, we will assign those basic Custom Switches we created to sound files for each flight mode, and lastly add advanced Custom Switches to sound Armed and Dsarmed when you Yaw your sticks right or left.
    http://easily.In/
  • Troy, thanks for your contribution.  I assume you will still need the Custom Switches (CS) to assign the sound files. In step 3, we continue by taking the 6 CS and assign a sound track to each flight mode.
