YANGDA FW-250 is a reliable and affordable VTOL fixed-wing plane designed for long-range inspection, survey, aerial photography, agriculture, search and rescue and public safety applications. As a fixed-wing UAV with VTOL and hover capabilities, the FW-250 features a modular airframe that can be set up in less than 10 minutes, does not require runway or catapult to get airborne. Once in the air, the aircraft transitions to horizontal flight as a push-prop fixed-wing.
Tool-free assembly
Due to its modular airframe design, FW-250 can be set up in less than 10 minutes by a single man.
Long flight time
FW-250 airframe is using light-weight and high strength composite material, which will enable the fixed-wing plane to fly up to 2 hours with 2KG payload, at an average cruising speed of 75KM/H.
Multiple camera options
These cameras are compatible with FW-250 VTOL aircraft: Sky Eye-U30 30X zoom camera, Eagle Eye-30IE-U 2-axis 30X EO/IR camera.
Specification
Wingspan: 2.5m
Fuselage: Composites
Frame Weight: 2.68kg
Total Weight: 5.5kg(without battery)
Max Take-off Weight: 12kg
Max Payload: 2kg
Flight Time: 2 hours with 2KG payload
Max Speed: 100km/h
Stall Speed: 15m/s-16m/s
Altitude: 3000m
RTF Combo
1 x YANGDA FW-250 VTOL fixed-wing airframe
4 x T-motor MN505 KV260
4 x T-motor FLAME 60A ESC
2 x T-motor 1654 CF Propeller CW&CCW
1 x T-motor 4120 KV250
1 x T-motor 12S 60A ESC
1 x 15x8 Wooden Propeller CW
4 x DS135MG Servo
1 x Px4 Air Speedometer
1 x ASSAN UBEC-8A
1 x Power Monitor Module
1 x Pixhawk 2.1 Standard Set with Here 2 GNSS
1 x YR16S Radio Controller
1 x Assembly and Flight Test Service
Photos
3689739051?profile=original
3689739183?profile=original
3689739224?profile=original3689739138?profile=original3689739247?profile=original3689739257?profile=original
  • I know it well! You’re the one who deleted my comment and I’m totally wrong about the name but that’s the only thing. It’s the foxtech baby shark, not nimbus and it is junk. Look what it’s made up of and the components. It looks like an aesthetic copy of component and wiring wise to get to the vtol motors and the wiring spec used bs current to them and adapters. It looks like a penguin wing in vtol form. I don’t get why people keep saying they are releasing “their” plane. It’s another companies with a maybe your camera on it as an option? So you’re a reseller or something but at least tell those out here who may not know it’s not something you made or yours or anything like that. Respect is due when something’s not misleading but that is worse.
  • Show some respect when you comment.
    Do not call it "junk" before you get to know it!
    FW250 is definitely not a rebranded NIMBUS VTOL, it supports max 2KG payload,12KG takeoff weight, made of carbon fiber and glass fiber, not that foam plane.
  • Deleted my comment! Ha!
    REBRANDED NIMBUS VTOL
    People have a right to know what they're getting.
  • Hi Amilcar Lucas, it is using Pixhawk 2.1
    RTF price: $7,699.00 USD
    Amilcar Lucas's Page
    Amilcar Lucas's Page on DIY Drones
  • What flight controller? Price?
