If you have a GoPro HD HERO2 camera there's a free firmware update that doubles the video bit rate, has a neutral white balance, and disables internal noise reduction, contrast adjustments, and sharpening. This dramatically improves the quality of the video and opens new doors for post processing of the video.
You can get the update from the GoPro website under support. It suggest updating through their CineForm video editing suite (also a free download).
Sarah, the update is downloaded through their editing software called CineForm. You can download CineForm from this link.
http://gopro.com/software-app/cineform-studio/
Or here's the link for the update itself, but it just downloads CineForm too.
http://gopro.com/support/hd-hero2-firmware-update/
When opening CineForm a window will come up asking if you want to import, edit, or manage devices. The devices option will download the new firmware once the camera is connected through USB.
Project Nadar, you should see the 24 FPS option once Protune mode is enabled in the options. It shows up as "1080 - 24T" when selecting the resolution to shoot with. If the Protune mode is not enabled from the settings you won't see the 24 FPS option.
Hi - I went the support link though don't see it - can anyone post the direct link to ProTune?
How do you upadte the camera? I did update it I think but I don't seem to be able to shoot in 24p.
I didn't say that those files are used by Protune. I just said it appeared after firmware upgrade and are consuming card space while being completely useless for someone without LCD or WiFi pack. If only I could disable creating them I would be satisfied.
Marooned, the LRV file is unrelated to the Protune mode. From my understanding of it the LRV file is a lower resolution version of the video recording used for preview purposes on the phone and tablet GoPro applications (less data to transfer wirelessly to the device running the application). It sucks that they take up space but SD cards are cheap and small.
Luke, I'm certainly not but "just disabling Protune mode" is causing what I described in point 2) in post above.
I'm for sure not grumbling on the new optional mode.
Marooned, are you a glass half empty kind of person? Just disable the Protune mode in the settings if you don't want to use it and the camera will go back to the automagical mode you're used to. Not everyone will want to use it which is why it can be enabled and disabled in a few seconds. I'm very happy with the new features personally because it gives so much more control over the footage in post production.
Low light noise is the reality with any camera that doesn't have a huge sensor. At least with Protune you can choose the noise reduction technique to use that works best for the shot instead of relying on whatever the camera does while recording like it used to. Overall it requires more work to use the Protune mode but the finished footage can look so much better, which is the whole point of the Protune mode (note they didn't call it Easytune mode).
Thanks i asked them a week ago when it will be released and they didin't give a clear answer :D
Regarding (1). Most likely the reason that you get more visible noise with Protune is that the neutral color profile and higher bandwidth is allowing you to see just how crappy the GoPro sensors actually is. Great for outdoor sunlight shots, but useless for anything else (depending on how picky you are). The default non Protune color profile hide much of this noise by over-filtering and crunching the colors.
Is there a way to downgrade? I find this update a serious mistake:
1) from my short test in low light I find quality with Protune enabled much worse (color noise, leakage on columns with light bulb)
2) when Protune is disabled, new .lrv files are created for each clip cutting down overall length of the movies (on trips it's kinda important). Files takes ~5.8% of the clip size so we have average ~5.8% less space on SD for our clips. This is some kind of small version of the clip.
3) with Protune no more 960@30 requiring editing every clip to be viewable (regular speed plus synced with voice) on regular player
4) and of course clips are more than two times larger (but this is of course desirable for better quality)
This was a very bad idea to "upgrade" my Hero2 :-/
