One of my projects is about establishing a solid, low-latency HD video link for FPV, SAR or surveillance and using accessible, affordable technology to do that. This is talking $4,000 for the entire setup here, which is mostly the macmini+720p goggles and which are reusable in different contexts.
The OSD is painted on the ground station (a mac mini) and visualized through the HD goggles (HMZ-T1). Even though the letters look pretty small, it's easier to see them through the goggles than on a regular computer screen.
In the past year I worked on refining this application and all the required settings for wifi, encoding, decoding to establish a relatively low-latency video link (120-150ms, relatively: for this type of technology). The telemetry data link that transmits all data from all onboard sensors at a rate of 30 Hz paves the way for a host of new ground-based applications. Examples include the integration with map and DEM data for improved navigation and virtual 3D overlays to make tunnels or paint the location of "buddies", "spotters" or other points of interest. If the lens properties are known and the camera is precisely fitted, this is not incredibly hard to achieve.
The OSD's bottom bar is also new and requires some explanation. Most OSD's provide raw data as in the top bar, data which has to be interpreted by the pilot during flight. In this app I'm reinterpreting the data based on work done in Cognitive Work Analysis (CWA). An example is that the pilot's primary concern is not the capacity left in the battery, but the distance that the battery still allows him to travel using that capacity and whether that's enough to make it home. The bottom bar thus relieves the pilot of these calculations and the bottom bar can be scanned in short time. If all is green, there are no immediate concerns. Bars reducing in size and changing color to red demonstrate a decrease in the available affordance for that operational concern.
Anyway, I gathered a lot of data and observations in this field test and I'm already working on improving those. This includes the causes for the video stutter, the failure of the telemetry link and so on. Both launches failed because the bungee cord got caught in the motor (twice!). I fixed that and managed to make another third successful launch, but that unfortunately didn't get recorded.
I cannot read russian, would you mind elaborating?
I can see from your post that you used h.264, which makes sense, but what did you use to encode it? What wifi where you using? May I ask what camera?
That is simply too cool.
Looks like you are developing this for release to industry. Looks really nice, the HUD is outstanding all the data you need but in a way that does not obstruct the view. Well done.....
Here is a piece of video with this videolink at a distance of about 12 km, height 700 m Video recorded on the ground.
https://www.youtube.com/watch?v=u8MxvR1eA8Q
Lazy, там же написано на фото - bullet M2, это Wifi на 2,4, 630мВт, путем нужных настроек позволяет получить нефиговую дальность. Стоит в РФ около 4000т.р.
Мы еще два года назад с ним на 15км летали, на такой дальности получали 10мБит что позволяло передавать 720p пожатое на борту h.264 при задержке 300-1000мс.
Если в него влезть с паяльником - то получали реалтайм картинку без сжатия, но дальность ограничена парой км.
This is incredible!
I would love some more specific info:
What are you using as your "video transmitter"?
what are you using to encode the video?
What codec are you using?
Can you please explain your use of WiFi?
How much bandwidth does this require?
What would you suspect the range will be like?
I have long been interested in doing a project like this; my original plan was to use regular transmitters but to encode to H.264 and then compress after the camera before passing it to the Vtx to cut down on bandwidth usage (2.4ghz or 5.8ghz would work with high compression)
This is really awesome stuff.
Gerard, what transmitter you use?
It's in the video, first couple of images. If you need more specific info, let me know.
Got any details on your equipment?
