Compatible with most 2.4Ghz video receiver systems this FPV camera and transmitter system is very versatile as well as light and very small.
The camera uses a quality glass lensed SONY CCD camera system.
Included:
1 x Sanyo CCD 1/3inch Camera
1 x Voltage Regulator
1 x Micro Light Weight Video Transmitter (100mW)
Camera specifications:
CCD SONY 1/3 CCD
Horizontal Resolution420TV Line
Minimum Illumination 0.01LUX/F1.2
Electric current 80MA
DSP+CCD CXD3142R+405AK
Size 38mm*38mm
FPV Tx Specifications:
Power: 100mW
Voltage Booster: 3.7v -> 12v
Weight: 8g
Channels: 4
Usage: 1 3S lipoly will power the camera and via the voltage regulator it will power the Tx on 5v.
Here is a start:
- Connect 1S lipo battery and make a connection from it to the camera AND to the voltage regulator.
- Make a connection from Voltage Regulator to the Transmitter
- Make a connection from camera to Transmitter (yellow wire in picture on HK website)
The white wire might be for audio (yellow is for video). I don't see anything about a mic in the specs.
Quote: "In effect, this means that if you were unlucky enough to have your Spectrum/JR radio select two closely spaced channels and someone was using a video transmitter on the same part of the band (effectively clobbering both DSM channels) then, should your model flew closer to that transmitter than it was to your own, you'd risk a lockout."
Note that this is not referring to a video TX that is on the model but at about the same distance from the model as the model remote control. With the video TX on the model (as for FPV) the situation would be much worse.
Based on other articles from the same site (http://www.rcmodelreviews.com/2.4ghzshootout.shtml) it appears that both HiTec and FrSky 2.4 GHz systems are more resilient to interference. Whether it will be resilient enough to safely operate a 2.4 GHz video TX close to the RC link receiver isn't documented - it might be worth testing.
That's the camera I was thinking of (there is a long thread somewhere on rcgroups about it). On close inspection the board looks slightly different from the Hobbyking one. No, that doesn't include a video TX. However there are several chinese vendors (e.g. bestofferbuy.com) that sell security video TX/RX combos (both 1.28 GHz and 2.4 GHZ) for around $50-$60 incl. shipping. Seeing that the HK offer doesn't include a video RX and shipping I think this is very similar pricing (and has been available for quite a while now). If you have a ham license the bestofferbuy.com 1.28 GHz TX gives you better range (output power 700 mW) and less interference with 2.4 GHz (you might still have some interference due to harmonics, but you can buy filters to reduce these).
1
2
3
of 3 Next
