HobbyKing FPV / UAV Fiberglass Kit Now Available!
FPV168.jpgFeaturing a full fiber glass fuselage with built up ply and balsa construction the HobbyKing FPV / UAV is set to raises the bar in FPV performance. The large motor mount area allows for a variety of motor sizes depending on your application. A slick fiber glass finish provides superior aerodynamics while the ridge airframe offers a greater level of flight performance. The large clear canopy is perfectly suited to FPV applications or can be removed or modified with ease for a custom setup. The Fuselage boasts ample space for FPV equipment and will allow for a variety of custom setups.
You will require a 35 to 42 size Burshless outrunner, 5 x 9g servos (one for each control surface and one for the steerable nose wheel), a 40 to 60Amp ESC, 3s to 4s 2200mah~4400mah Lipo battery and your own transmitter and receiver (Tx/Rx). All the general hard ware (Push rods, screws, landing gear etc) is included to get this kit underway.
Some modeling experience will be required to complete this kit, However the finished product will be of a high quality with superior flight characteristics and will last a life time.
Specifications:
Wing Span: 1660mm
Fuselage: 1190mm
Motor Mount Diameter: 58mm
Distance From Center of Mount to Fuse: 114mm
Dry Weight: 1300g
Required:
Motor: 35 to 42 series Outrunner
ESC: 40a to 60A
Servo: 5 x 9g
Battery: 3s to 4s 2200mah~4400mah
Available here: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=15236
  • That landing gear is pitiful!!
  • Postage 50$ for me, hmm..
  • Got a Dremel tool?  I can see someone making a removable tray which could hold
    some of their gear, or using this area for their main battery.
    Unless that wood panel full of holes is removable, it's gonna need a customm hatch on the side or bottom.
