Homemade Plane for GoPro: foam + depron
To watch the flight, go to: 2:33
I wanted to carry my GoPro (with housing) in a plane but without expending too much, so I built it by myself, using foam, depron and barbecue sticks.
The fuselage was done with EPS foam 12g/dm3 (isopor P0, comum de papelaria). Wings, ailerons, elevator and rudder with depron 4mm. I used some barbecue sticks to strengthen wings and tail. To assemble everything i used hot glue and packing tape.
Even though it had some crashes during this video, the plane is intact! Nothing happened to it. It's very resistant!
It is not flying very well because the wing angle of attack is 0 and the wing was not attached very well. I've already done these improvements but i still have not done a new flight.
Motor: D2826-6 2200kv Outrunner Motor
ESC: Hobbyking SS Series 40-50A ESC
Servo: Turnigy TG9e 9g / 1.5kg / 0.10sec Eco Micro Servo
Propeller: APC Style Propeller 6x4R
Battery: Turnigy 3s 2200mah 25C
RX: Turnigy 9x
Wingspan: 1200mm
Lenght: 1000mm
Chord: 250mm
Wing area: 30dm2
Wing weight: 252g
Fuselage thickness: 70mm
Fuselage weight (with motor, ESC, RX and servos): 468g
Battery weight: 200g
GoPro (with housing): 200g
Total weight: 1120g
Wing loading: 37,3g/dm2 (should use a bigger wing to have a slower flight)
This is the 2nd flight I've done with my homemade plane for carrying a GoPro. I advanced the CG a little bit and now it's flying much better, very smooth!
I still need to balance motor and prop.
Beautiful dusk, filmed with the homemade plane.
Some flybys, landings, panoramics ...
Changed the 2200kv motor + 6x4 prop to a 750kv motor + triblade 9x4.5: a little bit slower but prompt response when I add throttle and much better efficiency, almost double flight time (10min).
  • Hey Bernardo, nice plane and nce videos! maybe you have any more info about your plane, like dimensions of the parts, shape of the wings etc...? I'm looking for something to make in few free evenings, why my quad is crashed and waiting for new parts... :)
  • Tail heavy would cause it to bob up and down from my experience.Gets too much lift,then stalls,then nose drops gains lift again and repeats.
    Great work on the homemade.Try some pink XPS foam,its sand-able,paintable and cheap.
  • Thanks Adam ;) do you think that the heavy tail would be the responsible for the agressive movements of the pitch?
  • Nice bulild video, however way to tail heavy.
