    Electronic (digital) image stabilization only has some hard limits that you cannot get around, like motion blur caused by quick camera movements. The best approach is a hybrid system where you combine optical (mechanical) and electronic stabilization. Typically found in the semi-pro range of camcorders.
  • @mP1 ... I take your point, however, I thought the BeBop was doing a variant on the 4K-for-2K approach - oversized sensor with the image "stabilised" by cropping in to the image, which may require less CPU processing?
  • mP1, I have a Sony AS100V camera, that does do electronic image stabilization internally.  It does work.  Sort of.  It helps, but it's not perfect.  You still need a good gimbal.
  • I like it!
  • Chris, are 3DR exploring the digital stabilisation option as per the Parrot BeBop?
  • a 3 axis tarot would be great!
  • Nice Navoni, you are right, high frequency vibration ,  high centripetal and centrifugal acceleration are the most important point in a good gimbal controller.
  • What are the model of those high speed linear actuators?
    Are they electric or pneumatic actuators?
    Ben, yes, there is a coordinate system on the other wall and machine vision algorithms used to collect all the performance data. We didn't want to show all our secrets!
    Sure nice , but don't enought you don't have important variable as : high frequency vibration ,  high centripetal and centrifugal acceleration , HIT and wind  simulation .
    The better way for doing this kind of simulation is to use an ABB robot
    https://www.youtube.com/watch?v=bxbjZiKAZP4
    https://www.youtube.com/watch?v=92Ye2Q8U-rY
    Our new gimbal and imu  technology will be tested with this kind of robot.
    best
    Roberto
    Riding an ABB IRB 6600 Robot 1
    Back in the summer of 2006, we were using an ABB IRB 6600 robot (225 kg payload) for a project. In between the time that we took delivery of the robo…
