How far can the original Ardupilot + IMU go?!
Metaphorically speaking that is!
Seeing the development of code for the Ardupilot 'legacy*' has slowed right down I've decided to start modifying it myself to be a little more functional.
As I progress I'll post the updated code for everyone to benefit...
My aims so far are;
1) TWI between IMU and Autopilot
2) Bi-directional comms to GCS
3) External board to accomodate 2x pressure sensors, voltage + current, 12v upconverter for video & perhaps relay switches.
4) Overlay of telemetry data over video within the GCS to fly FPV without having to add another power hungry device onboard the UAV.
The list will no doubt increase as I get each step finished and have new requirements.
So far the TWI routines are pretty happy, bi-directional comms via XBee's is limited but working (PID's can be set from the GCS and attitude/GPS data can be received @ 10updates/sec + recorded )
Biggest problem I'm facing is the lack of available IO on the two ARDU boards, I'm guessing the external board may end up being another ATMega on TWI...
My UAV setup at the moment is;
1) Multiplex Easystar with mods;
- Larger rudder
- Rudder servo moved to tail
- Removable + strengthened compartment under the wings for mounting the IMU on the CG (And allowing easy access to the ESC)
- Outrunner hacker 12L and mods to fit it
- New canopy section to accomodate the GPS, Ardupilot and camera (This is a work in progress)
2) ArduPilot + ArduIMU + Mediatek 10hz GPS
Will have to add some pics when I get a chance...
BTW as I'm developing the GCS in VB6.0 I need to try and find some FREE! .ocx aircraft controls - anyone know where I can find such a beast?
  • Yup, looks like I was drinking a little too much and threw up in ASCII !
  • Of course You will never see this due to the long scroll time and carpeltunel I warned you about before.
    You Auses. Can you get me a job down there ?
  • Kevin, That exactly what the googlecode is for. Locationaly challenged teams to work on the same project. I have been working solo, but I'm sure you can give team members permissions. The'rs an SVN system that keeps track of changes, but I haven't used it yet. Like I said I am a total beginner as a coder, but I do think I have good ideas, I just struggle with the implementation. I have become very good at de-bugging due to all my typos and other errors :)
  • ok Greg, noted a few minutes too late...
    I'll have a look into starting a google code page but it would be nice to have an open area for people to book out code and upload their own changes to help progress this faster.
  • Just be aware that this code is initial and untested in the air! Also, a bit of data has been stripped out to speed sending and processing and I don't think the TWI comms lost routines work yet. I will be improving on this unfinished code in the next few weeks and posting it as it progresses.
  • The Ardupilot IMU routine, thanks to MarkW for the original design. Hopefully this will give most people a start into TWI.
    #if GPS_PROTOCOL == 6
    // Performance Monitoring variables
    // Data collected and reported for ~1 minute intervals
    //int mainLoop_count = 0; //Main loop cycles since last report
    byte IMU_buffer[30];
    byte payload_length = 0;
    byte payload_counter = 0;
    //IMU Checksum
    byte ck_a = 0;
    byte ck_b = 0;
    byte IMU_ck_a = 0;
    byte IMU_ck_b = 0;
    * Here you have all the stuff for data reception from the IMU_GPS
    void init_gps(void)
    GPS_fix = BAD_GPS;
    IMU Message format
    Byte(s) Value
    0-3 Header "DIYd"
    4 Payload length = 6
    5 Message ID = 2
    6,7 roll Integer (degrees*100)
    8,9 pitch Integer (degrees*100)
    10,11 yaw Integer (degrees*100)
    12,13 checksum
    IMU Message format - new with Airspeed!
    Byte(s) Value
    0-3 Header "DIYd"
    4 Payload length = 8
    5 Message ID = 4
    12,13 airspeed Integer (meters*100)
    14,15 checksum
    GPS Message format
    Byte(s) Value
    0-3 Header "DIYd"
    4 Payload length = 14
    5 Message ID = 3
    6-9 longitude Integer (value*10**7)
    10-13 latitude Integer (value*10**7)
    14,15 altitude Integer (meters*10)
    16,17 gps speed Integer (M/S*100)
    18,19 gps course not used
    20,21 checksum
    IMUdata imuData;
    GPSdata gpsData;
    void decode_gps(void)
    static unsigned long IMU_timer = 0; //used to set PROBLEM flag if no data is received.
    if (newmsg){
    newmsg = false;
    if((DIYmillis() - IMU_timer) > 500)
    { //If we don't receive IMU data in 1/2 second, set flag
    imu_ok = false;
    void receiveEvent(int size)
    // first byte is message ID
    byte msgID = Wire.receive();
    payload_counter=0;
    ck_a = 0;
    ck_b = 0;
    uint32_t now = millis();
    switch (msgID) {
    case 0x03: //IMUdatafs
    if((size == sizeof(imuData))&&(copyData(msgID, (uint8_t*)&imuData, size)))
    roll_sensor = imuData.roll_sensor;
    pitch_sensor = imuData.pitch_sensor;
    ground_course = imuData.yaw_sensor;
    imu_ok = true;
    IMU_timer = DIYmillis(); //Restarting timer...
    break;
    case 0x04:
    if((size == sizeof(gpsData))&&(copyData(msgID, (uint8_t*)&gpsData, size)))
    GPS_timer = now;
    gps_messages_received++;
    current_loc.lng = gpsData.lng; // Lat and Lon * 10**7
    current_loc.lat = gpsData.lat;
    //Storing GPS Height above the sea level
    current_loc.alt = (long)gpsData.alt * 10; // Altitude in meters * 100
    //Storing Speed (3-D)
    ground_speed = (float)gpsData.ground_speed; // Speed in cm/sec
    // removed to shorten GPSdata struct below 32 bytes (TWI buffer length)
    // iTOW = gpsData.gps_time;// Time of Week in milliseconds
    // copy UTC (replaces TOW for NMEA GPS)
    //memcpy(&gpsTime, &(gpsData.utc), sizeof(UTC));
    imu_health = gpsData.imu_health;
    roll_sensor = gpsData.roll_sensor;
    pitch_sensor = gpsData.pitch_sensor;
    ground_course = gpsData.yaw_sensor;
    GPS_fix = VALID_GPS;
    GPS_new_data = true;
    imu_ok = true;
    GPS_timer = DIYmillis(); //Restarting timer...
    else
    // Serial.println("GPS Data Failed");
    break;
    if((DIYmillis() - GPS_timer) > 2000)
    if(GPS_fix != FAILED_GPS)
    GPS_fix = BAD_GPS;
    if((DIYmillis() - GPS_timer) > 10000)
    GPS_fix = FAILED_GPS;
    // Serial.println("MSG \t No GPS, last 10s \t ***");
    bool copyData(uint8_t msgID, uint8_t *IMU_buffer, int nbytes) {
    bool valid = false;
    int csum = 0;
    ck_a=0;
    ck_b=0;
    //checksum(msgID);
    IMU_buffer[0] = msgID;
    for (int j=1; j
    byte data = Wire.receive();
    IMU_buffer[j] = data;
    checksum(data);
    IMU_ck_a = Wire.receive();
    IMU_ck_b = Wire.receive();
    if((ck_a == IMU_ck_a)&&(ck_b == IMU_ck_b))
    valid = true;
    else
    newmsg = true;
    valid = false;
    return valid;
    void checksum(byte data)
    ck_a += data;
    ck_b += ck_a;
    // Join 4 bytes into a long
    int32_t join_4_bytes(byte Buffer[])
    longUnion.byte[0] = *Buffer;
    longUnion.byte[1] = *(Buffer+1);
    longUnion.byte[2] = *(Buffer+2);
    longUnion.byte[3] = *(Buffer+3);
    return(longUnion.dword);
    #endif
  • Kevin, I don't think that you can include a file, only pics & links. It must be part of the blog entry and that wouldn't be good to scroll thru. You can only include a link to it(button left of camera button), That,s why you need to start a googlecode page. It's free and if I figured out how do do it I'm sure you can. Its password protected an only you can change it. Then include a link to it, which I still have trouble with if I haven't done it for a while.
  • ok I'll attach as text the main and TWI routines for the IMU... I will attach the library files tonight / tomorrow. I've ended up hacking the Ardupilot so I'll need to get the release version and add the TWI functions as an option, I'll do this in the next few days and upload the code.
    ***Main Function***
    // Released under Creative Commons License
    // Code by Jordi Munoz and William Premerlani, Supported by Chris Anderson and Doug Weibel
    // Version 1.0 for flat board updated by Doug Weibel and Jose Julio
    // Version 1.7 includes support for SCP1000 absolute pressure sensor
    // Version 1.8 uses DIYDrones GPS, FastSerial, and Compass libraries
    // Axis definition: X axis pointing forward, Y axis pointing to the right and Z axis pointing down.
    // Positive pitch : nose up
    // Positive roll : right wing down
    // Positive yaw : clockwise
    //---Added for TWI---
    #define TWI_FREQ 400000L
    #include
    #include
    #include // ArduPilot Fast Serial Library
    #include // ArduPilot GPS library
    #include // ArduPilot Mega Magnetometer Library
    #include
    // This section contains USER PARAMETERS !!!
    // *** NOTE! Hardware version - Can be used for v1 (daughterboards) or v2 (flat)
    #define BOARD_VERSION 2 // 1 For V1 and 2 for V2
    #define GPS_CONNECTION 0 // 0 for GPS pins, 1 for programming pins
    // GPS Type Selection - Note Ublox or MediaTek is recommended. Support for NMEA is limited.
    #define GPS_PROTOCOL 4 // 1 - NMEA, 2 - EM406, 3 - Ublox, 4 -- MediaTek
    // Enable Air Start uses Remove Before Fly flag - connection to pin 6 on ArduPilot
    #define ENABLE_AIR_START 0 // 1 if using airstart/groundstart signaling, 0 if not
    #define GROUNDSTART_PIN 8 // Pin number used for ground start signal (recommend 10 on v1 and 8 on v2 hardware)
    /*Min Speed Filter for Yaw drift Correction*/
    #define SPEEDFILT 2 // >1 use min speed filter for yaw drift cancellation (m/s), 0=do not use speed filter
    /*For debugging propurses*/
    #define PRINT_DEBUG 0 //Will print Debug messages
    //OUTPUTMODE=1 will print the corrected data, 0 will print uncorrected data of the gyros (with drift), 2 will print accelerometer only data
    #define OUTPUTMODE 1
    #define PRINT_DCM 0 //Will print the whole direction cosine matrix
    #define PRINT_ANALOGS 0 //Will print the analog raw data
    #define PRINT_EULER 0 //Will print the Euler angles Roll, Pitch and Yaw
    #define PRINT_GPS 0 //Will print GPS data
    // *** NOTE! To use ArduIMU with ArduPilot you must select binary output messages (change to 1 here)
    #define PRINT_BINARY 1 //Will print binary message and suppress ASCII messages (above)
    // *** NOTE! Performance reporting is only supported for Ublox. Set to 0 for others
    #define PERFORMANCE_REPORTING 0 //Will include performance reports in the binary output ~ 1/2 min
    /* Support for optional magnetometer (1 enabled, 0 dissabled) */
    #define USE_MAGNETOMETER 0 // use 1 if you want to make yaw gyro drift corrections using the optional magnetometer
    // Local magnetic declination
    // I use this web : http://www.ngdc.noaa.gov/geomagmodels/Declination.jsp
    #define MAGNETIC_DECLINATION 1.37 // corrects magnetic bearing to true north
    /* Support for optional barometer (1 enabled, 0 dissabled) */
    #define USE_BAROMETER 0 // use 1 if you want to get altitude using the optional absolute pressure sensor
    #define ALT_MIX 50 // For binary messages: GPS or barometric altitude. 0 to 100 = % of barometric. For example 75 gives 25% GPS alt and 75% baro
    #define TWI_MODE 1 //when enabled, send data via TWI
    // End of user parameters
    #define SOFTWARE_VER "1.8"
    // GPS Selection
    FastSerialPort0(Serial); // Instantiate the fast serial driver
    #if GPS_PROTOCOL == 1
    AP_GPS_NMEA GPS(&Serial);
    #elif GPS_PROTOCOL == 2
    AP_GPS_406 GPS(&Serial);
    #elif GPS_PROTOCOL == 3
    AP_GPS_UBLOX GPS(&Serial);
    #elif GPS_PROTOCOL == 4
    AP_GPS_MTK GPS(&Serial);
    #else
    # error Must define GPS_PROTOCOL with a valid value.
    #endif
    // ADC : Voltage reference 3.3v / 10bits(1024 steps) => 3.22mV/ADC step
    // ADXL335 Sensitivity(from datasheet) => 330mV/g, 3.22mV/ADC step => 330/3.22 = 102.48
    // Tested value : 101
    #define GRAVITY 101 //this equivalent to 1G in the raw data coming from the accelerometer
    #define Accel_Scale(x) x*(GRAVITY/9.81)//Scaling the raw data of the accel to actual acceleration in meters for seconds square
    #define ToRad(x) (x*0.01745329252) // *pi/180
    #define ToDeg(x) (x*57.2957795131) // *180/pi
    // LPR530 & LY530 Sensitivity (from datasheet) => 3.33mV/º/s, 3.22mV/ADC step => 1.03
    // Tested values : 0.96,0.96,0.94
    #define Gyro_Gain_X 0.92 //X axis Gyro gain
    #define Gyro_Gain_Y 0.92 //Y axis Gyro gain
    #define Gyro_Gain_Z 0.94 //Z axis Gyro gain
    #define Gyro_Scaled_X(x) x*ToRad(Gyro_Gain_X) //Return the scaled ADC raw data of the gyro in radians for second
    #define Gyro_Scaled_Y(x) x*ToRad(Gyro_Gain_Y) //Return the scaled ADC raw data of the gyro in radians for second
    #define Gyro_Scaled_Z(x) x*ToRad(Gyro_Gain_Z) //Return the scaled ADC raw data of the gyro in radians for second
    #define Kp_ROLLPITCH 0.015
    #define Ki_ROLLPITCH 0.000010
    #define Kp_YAW 1.2
    //#define Kp_YAW 2.5 //High yaw drift correction gain - use with caution!
    #define Ki_YAW 0.00005
    #define ADC_WARM_CYCLES 75
    #define FALSE 0
    #define TRUE 1
    //------Added for TWI------
    #define ARDUIMU_ADDR 1 //my address
    #define ARDUPILOT_ADDR 2 //the ardupilot address
    #define IPC_CONNECT 2
    uint8_t newMessage;
    float G_Dt=0.02; // Integration time (DCM algorithm)
    long timeNow=0; // Hold the milliseond value for now
    long timer=0; //general purpuse timer
    long timer_old;
    long timer24=0; //Second timer used to print values
    boolean groundstartDone = false; // Used to not repeat ground start
    float AN[8]; //array that store the 6 ADC filtered data
    float AN_OFFSET[8]; //Array that stores the Offset of the gyros
    float Accel_Vector[3]= {0,0,0}; //Store the acceleration in a vector
    float Gyro_Vector[3]= {0,0,0};//Store the gyros rutn rate in a vector
    float Omega_Vector[3]= {0,0,0}; //Corrected Gyro_Vector data
    float Omega_P[3]= {0,0,0};//Omega Proportional correction
    float Omega_I[3]= {0,0,0};//Omega Integrator
    float Omega[3]= {0,0,0};
    // Euler angles
    float roll;
    float pitch;
    float yaw;
    int toggleMode=0;
    float errorRollPitch[3]= {0,0,0};
    float errorYaw[3]= {0,0,0};
    float errorCourse=180;
    float COGX=0; //Course overground X axis
    float COGY=1; //Course overground Y axis
    unsigned int cycleCount=0;
    byte gyro_sat=0;
    float DCM_Matrix[3][3]= {
    1,0,0 }
    0,1,0 }
    0,0,1 }
    float Update_Matrix[3][3]={{0,1,2},{3,4,5},{6,7,8}}; //Gyros here
    float Temporary_Matrix[3][3]={
    0,0,0 }
    0,0,0 }
    0,0,0 }
    // Startup GPS variables
    int gps_fix_count = 5; //used to count 5 good fixes at ground startup
    //ADC variables
    volatile uint8_t MuxSel=0;
    volatile uint8_t analog_reference = DEFAULT;
    volatile uint16_t analog_buffer[8];
    volatile uint8_t analog_count[8];
    #if BOARD_VERSION == 1
    uint8_t sensors[6] = {0,2,1,3,5,4}; // Use these two lines for Hardware v1 (w/ daughterboards)
    int SENSOR_SIGN[]= {1,-1,1,-1,1,-1,-1,-1,-1}; //Sensor: GYROX, GYROY, GYROZ, ACCELX, ACCELY, ACCELZ
    #endif
    #if BOARD_VERSION == 2
    uint8_t sensors[6] = {6,7,3,0,1,2}; // For Hardware v2 flat
    int SENSOR_SIGN[] = {1,-1,-1,1,-1,1,-1,-1,-1};
    #endif
    // Data collected and reported for ~1/2 minute intervals
    #if PERFORMANCE_REPORTING == 1
    int G_Dt_max = 0.0; //Max main loop cycle time in milliseconds
    byte gyro_sat_count = 0;
    byte adc_constraints = 0;
    byte renorm_sqrt_count = 0;
    byte renorm_blowup_count = 0;
    byte gps_messages_sent = 0;
    long perf_mon_timer = 0;
    #endif
    unsigned int imu_health = 65012;
    boolean GPS_light = false;
    boolean SATGYRO_light = false;
    boolean YAWDRIFT_light = false;
    int gps_sync_count = 0;
    int gps_nosync = 0;
    int IMU_count = 0;
    // This section contains SCP1000_D11 PARAMETERS !!!
    #if USE_BAROMETER == 1
    #define SCP_MODE (9) // 9 = high speed mode, 10 = high resolution mode
    #define PRESSURE_ADDR (0x11U) // IIC address of the SCP1000
    // ************ #define START_ALTITUDE (217U) // default initial altitude in m above sea level
    // When we have to manage data transfers via IIC directly we need to use the following addresses
    fs// IIC address of the SCP1000 device forms the Top 7 bits of the address with the R/W bit as the LSB
    #define READ_PRESSURE_ADDR (PRESSURE_ADDR<<1 | 1)
    #define WRITE_PRESSURE_ADDR (PRESSURE_ADDR<<1)
    // SCP1000 Register addresses
    #define SNS_ADDR_POPERATION (0x03U) // OPERATON register
    #define SNS_ADDR_PSTATUS (0x07U) // STATUS register
    #define SNS_ADDR_PPRESSURE (0x80U) // DATARD16 Register (pressure)
    #define SNS_ADDR_DATARD8 (0x7FU) // DAYARD8 Register
    #define SNS_ADDR_PTEMP (0x81U) // TEMPOUT Register (temperature)
    #ifndef TRUE
    #define TRUE (0x01)
    #endif
    #ifndef FALSE
    #define FALSE (0x00)
    #endif
    int temp_unfilt = 0;
    int temperature = 0;
    unsigned long press = 0;
    unsigned long press_filt = 0;
    unsigned long press_gnd = 0;
    long ground_alt = 0; // Ground altitude in centimeters
    long press_alt = 0; // Pressure altitude in centimeters
    #endif
    void setup()
    Serial.begin(38400, 128, 16);
    #if TWI_MODE
    Wire.begin(); // join i2c bus
    #endif
    pinMode(2,OUTPUT); //Serial Mux
    if (GPS_CONNECTION == 0){
    digitalWrite(2,HIGH); //Serial Mux
    } else {
    digitalWrite(2,LOW); //Serial Mux
    pinMode(5,OUTPUT); //Red LED
    pinMode(6,OUTPUT); // Blue LED
    pinMode(7,OUTPUT); // Yellow LED
    pinMode(GROUNDSTART_PIN,INPUT); // Remove Before Fly flag (pin 6 on ArduPilot)
    digitalWrite(GROUNDSTART_PIN,HIGH);
    digitalWrite(5,HIGH);
    delay(100);
    digitalWrite(6,HIGH);
    delay(100);
    digitalWrite(7,HIGH);
    delay(100);
    digitalWrite(5,LOW);
    delay(100);
    digitalWrite(6,LOW);
    delay(100);
    digitalWrite(7,LOW);
    Analog_Reference(EXTERNAL);//Using external analog reference
    Analog_Init();
    debug_print("Welcome...");
    debug_print("You are using Hardware Version 1...");
    #endif
    debug_print("You are using Hardware Version 2...");
    #endif
    GPS.init(); // GPS Initialization
    debug_handler(0); //Printing version
    #if USE_MAGNETOMETER == 1
    APM_Compass.Init(); // I2C initialization
    debug_handler(3);
    #endif
    // SETUP FOR SCP1000_D11
    #if USE_BAROMETER==1
    debug_handler(4);
    setup_scp();
    #endif
    if(ENABLE_AIR_START){
    debug_handler(1);
    startup_air();
    }else{
    debug_handler(2);
    startup_ground();
    delay(250);
    Read_adc_raw(); // ADC initialization
    timer=DIYmillis();
    delay(20);
    void loop() //Main Loop
    timeNow = millis();
    if((timeNow-timer)>=20) // Main loop runs at 50Hz
    timer_old = timer;
    timer = timeNow;
    mainLoop_count++;
    if (timer-timer_old > G_Dt_max) G_Dt_max = timer-timer_old;
    #endif
    G_Dt = (timer-timer_old)/1000.0; // Real time of loop run. We use this on the DCM algorithm (gyro integration time)
    if(G_Dt > 1)
    G_Dt = 0; //Something is wrong - keeps dt from blowing up, goes to zero to keep gyros from departing
    // *** DCM algorithm
    Read_adc_raw();
    Matrix_update();
    Normalize();
    Drift_correction();
    Euler_angles();
    #if PRINT_BINARY == 1 && TWI_MODE == 0
    printdata(); //Send info via serial
    #endif
    #if TWI_MODE
    sendTWI();
    #endif
    //Turn on the LED when you saturate any of the gyros.
    if((abs(Gyro_Vector[0])>=ToRad(300))||(abs(Gyro_Vector[1])>=ToRad(300))||(abs(Gyro_Vector[2])>=ToRad(300)))
    gyro_sat=1;
    gyro_sat_count++;
    #endif
    if(!SATGYRO_light)
    SATGYRO_light = 1;
    cycleCount++;
    // Do these things every 6th time through the main cycle
    // This section gets called every 1000/(20*6) = 8 1/3 Hz
    // doing it this way removes the need for another 'millis()' call
    // and balances the processing load across main loop cycles.
    switch (cycleCount) {
    case(0):
    GPS.update();
    break;
    case(1):
    //Here we will check if we are getting a signal to ground start
    if(digitalRead(GROUNDSTART_PIN) == LOW && groundstartDone == false)
    startup_ground();
    break;
    case(2):
    ReadSCP1000(); // Read I2C absolute pressure sensor
    press_filt = (press + 2l * press_filt) / 3l; //Light filtering
    //temperature = (temperature * 9 + temp_unfilt) / 10; We will just use the ground temp for the altitude calculation
    #endif
    break;
    case(3):
    #if USE_MAGNETOMETER==1
    APM_Compass.Read(); // Read magnetometer
    APM_Compass.Calculate(roll,pitch); // Calculate heading
    #endif
    break;
    case(4):
    // Display Status on LEDs
    // GYRO Saturation indication
    if(gyro_sat>=1)
    SATGYRO_light = 1;
    digitalWrite(5,HIGH); //Turn Red LED when gyro is saturated.
    if(gyro_sat>=8) // keep the LED on for 8/10ths of a second
    gyro_sat=0;
    else
    gyro_sat++;
    else
    if(SATGYRO_light)
    SATGYRO_light = 0;
    // YAW drift correction indication
    if(GPS.ground_speed
    if(!YAWDRIFT_light)
    digitalWrite(7,HIGH); // Turn on yellow LED if speed too slow and yaw correction supressed
    YAWDRIFT_light = 1;
    else
    if(YAWDRIFT_light)
    YAWDRIFT_light = 0;
    // GPS Fix indication
    if(GPS.fix>=1)
    if((!GPS_light))
    digitalWrite(6,HIGH); //Turn Blue LED when gps is fixed.
    GPS_light = 1;
    else if (GPS.new_data == 1)
    toggleMode = abs(toggleMode-1); // Toggle blue light on and off to indicate NMEA sentences exist, but no GPS fix lock
    if (toggleMode==0)
    digitalWrite(6, LOW); // Blue light off
    GPS_light = 0;
    else
    digitalWrite(6, HIGH); // Blue light on
    GPS_light = 1;
    else
    if((GPS_light))
    GPS_light = 0;
    break;
    case(5):
    cycleCount = -1; // Reset case counter, will be incremented to zero before switch statement
    #if !PRINT_BINARY && !TWI_MODE
    #endif
    break;
    if (timeNow-perf_mon_timer > 20000)
    printPerfData(timeNow-perf_mon_timer);
    perf_mon_timer=timeNow;
    #endif
    void startup_ground(void)
    uint16_t store=0;
    int flashcount = 0;
    debug_handler(2);
    for(int c=0; c
    delay(50);
    Read_adc_raw();
    delay(50);
    Read_adc_raw();
    delay(20);
    Read_adc_raw();
    for(int y=0; y<=5; y++) // Read first initial ADC values for offset.
    AN_OFFSET[y]=AN[y];
    ReadSCP1000();
    press_gnd = press;
    temperature = temp_unfilt;
    delay(20);
    #endif
    for(int i=0;i<400;i++) // We take some readings...
    Read_adc_raw();
    for(int y=0; y<=5; y++) // Read initial ADC values for offset (averaging).
    AN_OFFSET[y]=AN_OFFSET[y]*0.8 + AN[y]*0.2;
    delay(20);
    if(flashcount == 5) {
    if(flashcount >= 10) {
    flashcount = 0;
    ReadSCP1000();
    press_gnd = (press_gnd * 9l + press) / 10l;
    #endif
    flashcount++;
    AN_OFFSET[5]-=GRAVITY*SENSOR_SIGN[5];
    Serial.println(AN_OFFSET[y]);
    store = ((AN_OFFSET[y]-200.f)*100.0f);
    eeprom_busy_wait();
    eeprom_write_word((uint16_t *) (y*2+2), store);
    while (gps_fix_count > 0 && USE_BAROMETER) {
    GPS.update();
    // Serial.print(gpsFix);
    // Serial.print(", ");
    // Serial.println(gpsFixnew);
    if (GPS.fix == 1 && GPS.new_data == 1) {
    GPS.new_data = 0;
    gps_fix_count--;
    press_filt = press_gnd;
    ground_alt = GPS.altitude;
    eeprom_busy_wait();
    eeprom_write_dword((uint32_t *)0x10, press_gnd);
    eeprom_busy_wait();
    eeprom_write_word((uint16_t *)0x14, temperature);
    eeprom_busy_wait();
    eeprom_write_word((uint16_t *)0x16, (ground_alt/100));
    #endif
    groundstartDone = true;
    debug_handler(6);
    void startup_air(void)
    uint16_t temp=0;
    eeprom_busy_wait();
    temp = eeprom_read_word((uint16_t *) (y*2+2));
    AN_OFFSET[y] = temp/100.f+200.f;
    eeprom_busy_wait();
    press_gnd = eeprom_read_dword((uint32_t *) 0x10);
    eeprom_busy_wait();
    temperature = eeprom_read_word((uint16_t *) 0x14);
    eeprom_busy_wait();
    ground_alt = eeprom_read_word((uint16_t *) 0x16);
    ground_alt *= 100;
    #endif
    Serial.println("***Air Start complete");
    void debug_print(char string[])
    #if PRINT_DEBUG != 0
    Serial.print("???");
    Serial.print(string);
    Serial.println("***");
    #endif
    void debug_handler(byte message)
    static unsigned long BAD_Checksum=0;
    switch(message)
    case 0:
    Serial.print("???Software Version ");
    Serial.print(SOFTWARE_VER);
    break;
    case 1:
    Serial.println("???Air Start!***");
    break;
    case 2:
    Serial.println("???Ground Start!***");
    break;
    case 3:
    Serial.println("???Enabling Magneto...***");
    break;
    case 4:
    Serial.println("???Enabling Pressure Altitude...***");
    break;
    case 5:
    Serial.println("???Air Start complete");
    break;
    case 6:
    Serial.println("???Ground Start complete");
    break;
    case 10:
    BAD_Checksum++;
    Serial.print("???GPS Bad Checksum: ");
    Serial.print(BAD_Checksum);
    Serial.println("...***");
    break;
    default:
    Serial.println("???Invalid debug ID...***");
    break;
    #endif
    EEPROM memory map
    0 0x00 Unused
    1 0x01 ..
    2 0x02 AN_OFFSET[0]
    3 0x03 ..
    4 0x04 AN_OFFSET[1]
    5 0x05 ..
    6 0x06 AN_OFFSET[2]
    7 0x07 ..
    8 0x08 AN_OFFSET[3]
    9 0x09 ..
    10 0x0A AN_OFFSET[4]
    11 0x0B ..
    12 0x0C AN_OFFSET[5]
    13 0x0D ..
    14 0x0E Unused
    15 0x0F ..
    16 0x10 Ground Pressure
    17 0x11 ..
    18 0x12 ..
    19 0x13 ..
    20 0x14 Ground Temp
    21 0x15 ..
    22 0x16 Ground Altitude
    23 0x17 ..
    *************END OF MAIN FUNCTION***************
    *****TWI_COMM FUNCTION*****
    * twi_comm.pde
    * Created on: Aug 2, 2010
    * Author: markw
    //Modified:
    //! 2010-11-13 K.Bloch !
    //! Updated structures !
    //! Reduced Protocol !
    //! Overheads !
    //! Integrated into IMU !
    #if TWI_MODE == 1
    APdata apData;
    //IPC Checksum
    byte ck_a = 0;
    byte ck_b = 0;
    byte IMU_ck_a = 0;
    byte IMU_ck_b = 0;
    int payload_error_count = 0;
    int checksum_error_count = 0;
    void sendTWI()
    // This section outputs binary data messages
    // Conforms to new binary message standard (12/31/09)
    byte IMU_buffer[23];
    int tempint, t_roll, t_pitch;
    int t_yaw;
    int ck;
    long templong;
    byte IMU_ck_a=0;
    byte IMU_ck_b=0;
    t_roll=ToDeg(roll)*100; //Roll (degrees) * 100 in 2 bytes
    t_pitch=ToDeg(pitch)*100; //Pitch (degrees) * 100 in 2 bytes
    tempint=ToDeg(yaw)*100; //Yaw (degrees) * 100 in 2 bytes
    if(tempint>18000) tempint -=36000;
    if(tempint<-18000) tempint +=36000;
    t_yaw = tempint;
    //------------------------------------------GPS DATA----------------------------------------------------------------
    // This section outputs the gps binary message when new gps data is available
    if((GPS.new_data==1)&&(GPS.fix!=0)) {
    gps_messages_sent++;
    #endif
    gps_sync_count = 0;
    GPS.new_data=0;
    IMU_buffer[0] = 0x04;
    ck=21;
    templong = GPS.longitude; //Longitude *10**7 in 4 bytes
    IMU_buffer[1]=templong&0xff;
    IMU_buffer[2]=(templong>>8)&0xff;
    IMU_buffer[3]=(templong>>16)&0xff;
    IMU_buffer[4]=(templong>>24)&0xff;
    templong = GPS.latitude; //Latitude *10**7 in 4 bytes
    IMU_buffer[5]=templong&0xff;
    IMU_buffer[6]=(templong>>8)&0xff;
    IMU_buffer[7]=(templong>>16)&0xff;
    IMU_buffer[8]=(templong>>24)&0xff;
    #if USE_BAROMETER==0
    tempint=GPS.altitude / 100; // Altitude MSL in meters * 10 in 2 bytes
    #else
    alti();
    tempint = (press_alt * ALT_MIX + GPS.altitude * (100-ALT_MIX)) / 10000; //Blended GPS and pressure altitude
    #endif
    IMU_buffer[9]=tempint&0xff;
    IMU_buffer[10]=(tempint>>8)&0xff;
    tempint=GPS.ground_speed; // Speed in M/S * 100 in 2 bytes
    IMU_buffer[11]=tempint&0xff;
    IMU_buffer[12]=(tempint>>8)&0xff;
    tempint=GPS.ground_course; // course in degreees * 100 in 2 bytes
    IMU_buffer[13]=tempint&0xff;
    IMU_buffer[14]=(tempint>>8)&0xff;
    IMU_buffer[15]=(imu_health>>8)&0xff;
    IMU_buffer[16]=t_roll&0xff;
    IMU_buffer[17]=(t_roll>>8)&0xff;
    IMU_buffer[18]=t_pitch&0xff;
    IMU_buffer[19]=(t_pitch>>8)&0xff;
    IMU_buffer[20]=t_yaw&0xff;
    IMU_buffer[21]=(t_yaw>>8)&0xff;
    for (int i=1;i
    IMU_ck_a+=IMU_buffer[i]; //Calculates checksums
    IMU_ck_b+=IMU_ck_a;
    IMU_buffer[22]=IMU_ck_a;
    IMU_buffer[23]=IMU_ck_b;
    Wire.beginTransmission(ARDUPILOT_ADDR); // transmit to device
    for (int i=0;i
    Wire.endTransmission(); // stop transmitting
    } else {
    //------------------------------------------IMU DATA----------------------------------------------------------------
    // Serial.println("IMU"); // This is the message preamble
    // This section outputs the IMU orientatiom message
    IMU_buffer[0]=0x03;
    ck=6;
    IMU_buffer[1]=t_roll&0xff;
    IMU_buffer[2]=(t_roll>>8)&0xff;
    IMU_buffer[3]=t_pitch&0xff;
    IMU_buffer[4]=(t_pitch>>8)&0xff;
    IMU_buffer[5]=t_yaw&0xff;
    IMU_buffer[6]=(t_yaw>>8)&0xff;
    for (int i=1;i
    IMU_ck_b+=IMU_ck_a;
    IMU_buffer[7]=IMU_ck_a;
    IMU_buffer[8]=IMU_ck_b;
    for (int i=0;i
    #endif
    ********* END OF TWI_COMM FUNCTION *************
  • I would like to attach the first version of the TWI code - how do you add a .zip file to a blog entry?
  • Kevin, I have been working well for the past month on additional capability with the ArduPilot. I have got the 2 way coms thing working very well using the thermopile version. For the GCS hardware I am using a very tricked out Ardustation attached to my RC transmitter. The reasons for not using a laptop are purely logistical. I want to keep my eyes on the plane as much as possible and the Tx in my hands at all times. I don't have an assistant to run the GCS. That was my starting requirement, every thing in my hands.
    Also I designed the system to be very simple to use and not distract me from the aircraft. There are audio cues to every thing that happens with the AP,such as low batt, AP mode change, loss of GPS, loss of signal, ect. Then a temporary display you can glance down at when something happens. It also has a micro SD card data logger and automatic file name generation based on time. The AP polls the Ublox for the time and date and sends it to the GCS on start up. Automate as much as possible to keep the work load of the pilot. Oh ya, I almost forgot, all the PID gans are automatically up-linked to the AP on start up. And I can have multiple sets of gains for different models or conditions. The gains are stored on the GCS eeprom leaving the AP eeprom free for waypoints. Gain setting are all synchronized at start up automatically. They are also defaulted from the #defines which can bee programed an the ground as is normally done now. I also added a new AP mode. This comment is getting kind of long. I have been a very busy boy lately. Once you get going its hard to stop.
    The uplink is all done in binary and uses Fletcher algorithm check sums and replies from the AP, and re-sends data until a valid reply is received. This is very important to insure you don't get a wild gain or mode command and you now when you hit the send button that your command was really sent.
    I need to get the text in RAM thing figured out as the GCS is almost out. When I get all the bugs sorted and flight tested I will put up a blog post and link to my Google code page. My next project was going to get this working with the IMU. It will be easy with your TWI method. Right now I am sharing the serial port between the GPS and Xbee Which was no easy task.
    I haven't posted it yet because it not quite done and tested,but it's ~ 90% done and working. PM me if you want to collaborate. PS I am not on the dev team because I am still learning and didn't feel I was qualified enough, but I am leaning fast.
