I love my Spektrum Dx7 and my 2.4Ghz JR XPS9303 and i refused to trade its solid rock performance by a 72mhz radio just to increase range of my FPV/UAV. So in collaboration with my friend JB we find out the cheapest and secure way to amplify the signal, it even works in some Futabas and virtually with any 2.4Ghz radio, but some modifications are required. Lets see some options:-Spektrum Dx7 this is the cheapest solution for a very reliable 2.4Ghz radio, i used it for about a year and i never had any signal glitch (unless i fly beyond 2000 feet). The problem with this one is that you have to modify it, you need a SMD to U.FL adapter, drill a hole in the side of your radio and just connect and screw the adapter, no soldering required. If you have more than 5 hours of experience with Legos your qualified to do this job. Then you just need to connect the booster. The one in the picture (middle) is already modified.-If you have the awesome JR radio but is 72Mhz you can buy the Spektrum 2.4Ghz module and just insert it in the back of your TX, personally this is my favorite setup. It's a good deal because includes a $99 dlls receiver for free! Note that JR TX alone cost around $600 dlls, but you can get it for less, i got mine for 300 bucks with Spektrum Module included on R/C Groups =P. Remember you are looking for the JR XPS9303.If you have one of the fallowing Futaba radios:7U Series Radios8U Series Radios8J Series Radios9C Series Radios9Z Series RadiosFN Series RadiosYou can just go and buy the Spektrum 2.4Ghz module, easy and with no hassles. It's also a good deal because includes a $99 dlls receiver for free!
One of the advantages of the Spektrum receivers is the build in diversity system, you can even buy one with 4 satellites like this one, or buy a super tiny, tiny setup like this one, or the traditional one.The diversity is crucial to have a reliable link when you are flying far away, also Spektrum has a receiver for Carbon Fiber airplanes (Carbon Fiber blocks RF signals).The idea is to have the best reliable hardware with an SMA connector and the SMA extension cable, after that you are ready for the final step: Get an amplifier. But we are talking about a few hundred dollars here, if you get the weakest one of 100mW it will cost you around $150 dlls. This is not pocket friendly in my point of view. So again our Asians friends come to the rescue, after making some research around the net I've found on eBay and a home Wireless Amplifier, so i decided to give it a chance and i bought it for 60 bucks including shipping! Wow that's a good deal! The one i got is this one.Note that the amplifier needs 6Volts to work, you can get a cheap 6V power regulator from here and just make the adapter. A 3 Cell LIPO is enough to supply it for a long time.
After receiving the AMP i did some tests, here are my results:Before using the amplifier, i was able to fly around 3000 feet away (~1 km) using a 900Mhz@500mW Video transmitter. I never lost the video signal, only the radio link...Using a 1.3Ghz@1Watt Video transmitter i was unable to fly more than 2000 feet away (~600meters). So the 1.3Ghz Video transmitter reduces my 2.4Ghz Spektrum range...Then i got my cheap Asian amplifier and using a 2.4Ghz Patch Antenna i was able to fly around 2.6 miles (4.18Km) away without a single glitch, but i was unable to continue because now my video was causing me problems, hehe!Not bad at all! Honestly i don't need more than 2 miles of coverage, is really a long way for an EasyStar. In conclusion the maximum range for my setup still unknown, but the range achieved is more that 2.6 miles and the +2 extra miles of coverage gained for less than $100 dlls is really a good deal for me!
Now just remember this:-The range will be different in other setups.-Never turn on your radio without antenna.-Never turn on the Amplifier without antenna.-Note that in some country's this amplifier may be illegal.Thanks for watching!
  • This is some great info!
    I successfully modded my DX6i to have a reverse polarity SMA coming out of the top so I could use a booster. I made a little how-to on my Blog
    Still haven't range tested with the booster yet. but I will soon. (now that the weather is better)
    For normal flying I just use the antenna that came with the booster. When I try out the booster hopefully the 7 foot coax will give enough attenuation so I don't burn it out.
    3692206767?profile=original
    A "broke" and then "fixed" DX6i
    Ok, so far my blog sucks. But I'm going to try to make a honest effort to get at least one post in a day...or every other day....or maybe ju...
  • I think I might have FRIED my amp.  :(  Is there any way to test it and see??
    Tim
  • Thanks Mark.
    DX-7 standard antenna is Omnidirectional,  I think its close to 2db.
  • How much dbi has the standard DX7 antenna?
    Is it an omnidirectional antenna?
    Regards
    Roy
    Can you give more details for your antenna on booster, a patch, home made?
  • These are intense, thanks for sharing this information.  I love how with most things RC they can be modified to your wants and needs.  I really enjoy learning about new products and cadgets to improve your RC toys.  I found some cool RC cars that can be modified and updated to your needs.  How would a similar remote translate to an RC car?
    RC Cars
    Browse our vast array of RC cars from fast, electric, nitro and even gas powered RC Cars. Order your favorite Brushless RC Cars today at HobbyTron.com
  • Yes, antenna for the DX7, something with a SMA connector (not the standard one)
  • do you need such an amplifier on the tx AND rx ?
    or just on the TX ?
  • Ed,
    The stock DX7 antenna works fine, but:
    I wil take the stock DX7 antenna off and make a new connecton at the same place for:
    1; flying "normal" with a rubber duck antenna, but i don't no which one.
    2; Flying FPV with a booster .
    So this way i can choose.
